Tire problem
cairopd1069
I have a 2015 Coachman TT and I "accidentally" found a problem with one of my tires. I will pay a lot more attention to them now. I always keep them at 50lbs and the TT is stored under a carport and shielded from the weather when not in use. I discovered the right rear tire had worn excessively on the outer edge. We were on a trip so I changed the tire. When rolling it to put it away, I noticed the tire was separating within the tread and had a "gouge" on the outside edge. The set of tires are the ones that were on the TT when I bought it and none of the other ones "appear" to have any flaws at this point. If the pics will post, I would appreciate any input on what might have caused this problem. Trail Express 205/75/r14
Thanks in advance.
12 REPLIES 12
cairopd1069
phillyg, that would make sense. I'm looking at the Maxxis and the GY Endurance. I'm replacing all 4, might not need to, but I want peace of mind when towing something that big.
phillyg
It may not be alignment. Rather, the tread started seperating and quickly wore down the high side. Get alignment checked and take a look at the new GY Endurance tire that comes in 14" sizes.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
bstar1952
Had the same problem on my White Hawk last year. Not sure what caused it. Put a set of the new Carlilse H/Ds on. Have over 5,000 on them an no problems so far. Please let us know if an alignment issue. Cheers.....
Bstar1952
Bandera, Texas
2020 Ram 2500,6.4 Hemi
2019 (East to West) Della Terra 29KRK
Fastway E2 WHD Hitch
cairopd1069
Thanks for all the responses
Old-Biscuit
cairopd1069 wrote:
Mine is a tandem axle and the tire was worn on the outside edge. The separating tread is a major concern as well. Just trying to get some ideas on why only one tire is doing this. Of course I'm checking the others as well. Thanks for the response.
I take it they are 'C' rated tires......50PSI max psi
Trailer tires get abused....curb hopping, potholes, twisting motion/lateral forces when maneuvering, etc
Belts separate.
Alignment, bent spindle, BAD tire
Replace and be glad YOU found it vs blow out & damage
downtheroad
Yes, alignment problem
Also the cut shown in the 3 picture looks to be caused by hitting something.
Yes, replace all 4.
Replacement choices. I'd look at Maxxis 8008's or the new U.S. made Goodyear Endurance tires. (these look promising as far as ST tires go...)
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
budwich
do some basic checks maybe. Take the trailer out on an parking lot and setup so that you have run straight for a bit. Get a straight piece of wood / angle iron / whatever, long enough to straddle the two tire. check and see what kind of "gapping" there might be between the "straight edge" and your tires. It might give you a clue to where things are. Compare with the other side of tires. You can go from there. There are other checks that you can do also but that's one to get started.
cairopd1069
JCR-1
I have a Coachman as well and same problem. The problem is that they use a too small axle on their trailers. If its single axle like mine I had to replace the axle . Somehow the factory axle lost its camber.Probably due to overloading. The axle is rated at 3500 lbs and the **** trailer is like 3300 lbs dry. After adding some water and stuff you are exceeding the axle and you will wear on the inside.
aguablanco
I am having good luck with my Carlisle tires.
RichH
2017 Ram 1500 EcoDiesel
8 Speed Transmission
2010 Dutchmen 24 FB-SL
Curt 10,000# WDH
Never underestimate the power of stupid people in large groups.
cairopd1069
Thanks for the reply. I will take it to an alignment shop tomorrow. I am considering replacing all of them, but finding a consensus as to what tires are best is a chore!!
lanerd
I think I would replace all the tires.
As for the one wearing excessively on one edge, I would think that the tire/wheel is at a slight angle (toe out?). I would have it inspected by some one in an alignment shop.
Also, you have a Coachmen..not a Coachman.:D
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
