Jul-02-2016 09:37 AM
Jul-07-2016 09:45 AM
Tom/Barb wrote:
When I tried to repair a faulty radio antenna I found a two wire plastic tape attached to two 12" aluminum sticky tapes. only they were not attached. I remove the refer to get to this, and found no insulation at all.
Jul-06-2016 08:38 PM
Reddog1 wrote:covered wagon wrote:I could, but prefer they be seen by others to assist in identifying members with knowledge to offer or just someone looking for attention. There is also the possibility it could be true but not in my knowledge base.
Thank you Wayne, then why don't you delete them? It would be the best option wouldn't it?
Wayne
Jul-05-2016 03:26 PM
Jul-05-2016 11:52 AM
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Jul-05-2016 08:29 AM
Jul-05-2016 06:12 AM
Jul-04-2016 08:29 AM
Toad: 91 Zuke
Jul-04-2016 07:57 AM
Tom/Barb wrote:
We bought a Big foot 25' 2009. we thought (and was told) it was built like a Boston Whaler boat, it was not, they use 1/2" poly foam sheets glued to the walls. It sweated so bad the first winter we had 1/2" of ice on the interior any where you could look. `Snip
Jul-03-2016 09:56 PM
Jul-03-2016 07:40 PM
TxGearhead wrote:On the NL website, click on the "brochure" link. The brochure give details of construction.
Neither one's website is much help.
Jul-03-2016 06:44 PM
Jul-03-2016 12:35 PM
Z-Peller wrote:
When I owned my Bigfoot 25B25RQ trailer I installed a crank up tv antenna. This is a pic of the piece I cut out of the roof with a hole saw. .....layers consist of molded fiberglass shell, foam insulation, luan, fuzzy interior material...
Jul-03-2016 12:34 PM
HMS Beagle wrote:
I'm not sure how they build the trailers. I have owned 2 Bigfoot campers and one 5th wheel, spanning 1986 - 2008. I have looked at the construction of all of them, which was similar.
It is a molded top and bottom half, overlapped and joined at the trim line around the middle. After molding, they glue in sheets of styrofoam insulation using contact cement - 1" for the non-winter versions and 1 1/2" for the versions with the cold weather option in my experience. At many various places, pine or some other softwood is glued in place of the foam, this is for reinforcement or where things will be attached later. On the lower section of the camper, this is replaced by plywood, on my 2008 camper 1 1/2" of plywood. Then luan interior paneling is glued over that. Doors, windows, vents, cabinets are screwed to the pine placed there for that purpose. The cold weather option also included dual pane windows, worth the cost for the noise insulation alone.
This makes them: relatively watertight, as the only leaks are places where a hole has been cut or drilled (unfortunately often too many), there are no long leaking roof and wall joints. It also makes them difficult to modify, unless you are familiar with fiberglass work (then it is pretty easy).
I have said it before and will again: Bigfoot quality sucks, but it sucks less than any other brand. This is the RV industry after all. You will not have ice forming inside (maybe camped at the south pole?) - I've spent many nights in 15 degree weather, perfectly comfortable. I have not seen a more solidly built production camper, and I have looked. Better quality than my Safari motorhome, better than my Airstream trailer. Second hand sales prices are usually an indication. I sold my purchased new 1998 camper in 2012 for about 60% of what I paid for it. Try that with any other 14 year old RV.
Jul-03-2016 11:30 AM
