Black & Grey holding tank valves
lmccown
I have a 2005 Open road 31 ft and would like to replace the holding tank valves. Can this be done by a novice? They seem really hard to open and close.
8 REPLIES 8
joeprinter
Chuck&Gail wrote:
Before you do that, IMHO try this first.
Empty both tanks. Then spray half a can of silicone spray up the discharge pipe while operating valve. Put a squirt or two on the rod also. Repeat for second valve. Bet it fixes it.
Thanks Chuck, I will try this, just this week, broke 1/2 of the tee, just a matter of time.. Really hard to close.
"2012 Forest River 360 DS"
"Ford V-10"
"2013 Toyota Corolla on Tow Dolly"
Chuck_Gail
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
2010 Outback 230RS Toybox, 5390# UVW, 6800# Loaded
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories
I can't be lost because I don't care where this lovely road is going
lanerd
Good to know Bob.. thanks
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
Big_Katuna
Vaseline is a petroleum product and will damage the material.
Valterra the manufacturer recommends silicone grease sold at pool supply stores.
My Kharma ran over my Dogma.
skipnchar
I've replaced a few while on the road. Takes about 15 to 20 minutes and very basic tools. Of course you'll ALSO need a dump station so don't try it at a campsite.
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
lanerd
I just replaced both of mine this past winter and it really wasn't very difficult. It helps if you have sufficient area to be able to "pull" the two drain pipes apart by a 1/2 inch or so. I didn't and had to remove one of the pipes from its connection to the tank.
As mentioned, use vaceling or grease on the gaskets. I had mine all back together and realized that one of them had dropped out.
Ron
Ron & Sandie
TPMS: Pressure Pro
lmccown
Thanks for your help.
enblethen
Yes, an easy job.
Check for size of grey water drain. They vary.
The majority of the black tanks are 3 inch.
They use 1/4 on grey and 5/16 bolts on black.
Make sure tanks are empty. remove bolts, four on each valve. Remove old valve. New valve goes in reverse. Good to coat seals with vaseline or the like to hold in place while assembling.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
