Mar-01-2013 04:30 PM
Jun-27-2013 05:34 PM
westend wrote:
I would be thinking about securing the pipe with some good hangers. I thought most ABS drain pipes are solvent welded to the ABS tank. It sounds like you have a mix of materials.
Is it possible that you had a through-tank rubber seal on the pipe and the back half sheared off? Something like this:tank grommet
Jun-27-2013 02:04 PM
Jun-27-2013 11:05 AM
Jun-27-2013 09:58 AM
Jun-27-2013 09:19 AM
Mar-03-2013 08:25 AM
Mar-03-2013 08:09 AM
tvman44 wrote:
I think Eternabond tape would do the job permanently.
Mar-02-2013 01:09 PM
Mar-02-2013 08:30 AM
Mar-01-2013 09:04 PM
Mar-01-2013 07:38 PM
Mar-01-2013 05:17 PM
purplepossum wrote:
Like to stop the dripping leak on a short term basis while we're out. Think that this leak is the cause of problems I'm having with tank clogs. Think possibly most of the liquid is leaking and leaving the semi solids behind.
Any suggestion on products that will work under the above
conditions? Looking for a short term repair. Understand that I'll have to fix the problem on a more permanent basis when I return home.
Mar-01-2013 04:47 PM
