Black water tank cleaning
rbpru
After a month on the road we are finally home for a bit, till the weather warms up.
We dumped our black and gray water tanks and I purchased a toilet wand to spray the black water tank.
I was wondering if it would be worth the effort to rinse out the black tank and add bleach, since it is most likely going to set for a few months.
I still have issues with the guage always showing 2/3 full, and thought splashing some bleach water around might help.
20 REPLIES 20
popeyemth
I swear by the "GEO" method:
One cup Calgon water softener ( or 20 Mule Team Borax)
One cup cheap laundry detergent - I use powder because it's easier to store
Mix in 3-5 gallon water (we use 3 gallon mop bucket because it's handy)dump down toilet and a batch in bathtub .
Leave in tanks till full enough to dump, rinse, repeat and leave in tanks .
We premeasure and keep in zip lock bags in bathroom.
Senders work fine-every time.
"wine is a constant proof that God loves us, and loves to see us happy" ben franklin
Old-Biscuit
Why are you worrying about sanitizing a waste tank?
No Bleach needed.......the rinse with the wand is good enough.
Then add a couple of gallons of water back into black tank so the bottom stays wet.
Don't want it to dry out cause any stuff will dry out and stick....then it will accumulate and then you will have problems
Dump, rinse, add water......done until next time it is full. Then repeat.
downtheroad
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
downtheroad
A good rinse now and then is good.
Don't use bleach...It might kill some germs, but you aren't storing your food in it.
Leaving bleach in may harm the drain seal.
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
2oldman
Bleach won't likely help.
Here's an afternoon's reading:
dirty sensor 1
dirty sensor 2
dirty sensor 3
Clean sensors 2010
False black water reading
DutchmenSport
Yes, but make sure you rinse the bleach. Don't leave it sit in the tank, it will erode your slide valve. Rinse and drain. Then add a couple gallons of water to keep the slide seal from drying out.
It would be better if you added the bleach, about 5 - 10 gallons of water, took the camper on the road, let it slosh around real good, then bring it home, drain, rinse, and then add a couple gallons of water while it sits. This way the bleach will slosh and get on everything. Rinse well with your wand.
