Aug-30-2017 06:48 PM
Nov-20-2017 01:41 PM
Nov-20-2017 01:30 PM
Nov-20-2017 12:48 PM
Sep-03-2017 09:26 AM
Sep-03-2017 03:12 AM
Trackrig wrote:The water pump actually is one of the lower total power draws. How so? It is limited by the water supply! When the water is gone, the draw stops. At 3 GPM, a typical tank will only require 12-13 minutes of pump run time. Leaving a light or two on by mistake can draw far more power total as it keeps on draining the battery until it is dead!
If you run just the control panels, using the lanterns for lights, I'd expect the single 12V to last for 48 hours if it's in decent shape. Use the jumper cables if needed. If you have a slide that needs to be opened, use the jumper cables while operating it so the battery will last through everything else.
Use the water pump minimally for the toilets - use the camp ground toilets.
Bill
Sep-02-2017 05:49 PM
Aug-31-2017 07:17 PM
Aug-31-2017 01:26 PM
Aug-31-2017 11:03 AM
Aug-31-2017 10:13 AM
Aug-31-2017 08:35 AM
Aug-31-2017 08:09 AM
Aug-31-2017 07:59 AM
Aug-31-2017 07:53 AM
