Yup, mine did that earlier this Spring. It started acting up last Fall, and on 2 different trips, lost the brakes in the camper completely. This was our Springdale camper. Took the truck and the camper to our local dealer to figure out. I had several problems.
1st, one of the pin holes (that little clip), on the truck was bent and wasn't making good contact. So, they replaced the entire plug on the truck. Seemed to clear up the issue, until our next trip and the brake controller started doing the same thing again.
Took it back (truck and camper) to the dealer, and they checked out the camper. They replaced the pig-tail, seemed to clear up the problem... until the next trip and the controller would go crazy like your and no brakes. That's really scary driving with no trailer brakes ....
So, took truck and trailer back again this Spring (by now, we'd parked the camper for the winter). They checked it all REAL good this time and found out the wire to the actual brakes under the trailer had rubbed raw and was shorting out when it touched the metal it was rubbing. It only did this erratically. That's why when they fixed the plugs, it seemed to work again. Now mind you, the plugs were well worn, and I did have that bent pin, so I was perfectly OK they fixed that.
But after they replaced the wire leading to the brakes from the trailer's pig-tail, (they also repacked the bearing and inspected the brakes), it never happened again.
Four weeks ago we traded the Springdale for the Outback (below) and controller has absolutely NO issues with the new camper.
So, my advise, check the wires under the camper that lead to the brakes. See if there are any worn spots.
