Brake Smart Needed working or not
btexpress
Does any one have a BrakeSmart controller and or the transducer. I need to buy one to try to get my old one working.
4 REPLIES 4
BenK
Shouldn't be expensive...used similar on a windgenerator hydraulic brake system
They lasted about 3 years on that application...un-maned units in wind parks
How many miles/time did the last one last?
Consider having a spare as a just in case since the OEM has gone out of business
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
btexpress
I am working again, don't need one now, thanks.
kirbybear
You may purchase this part from our distribution partner; Digi-Key. They can be located at the following link: http://search.digikey.com/scripts/DkSearch/dksus.dll?Cat=1966259;keywords=SSI%20Technologies
The above info was from the transducer supplier of the unit on my BrakeSmart.
This is what I wrote to the suppler -----
Additional Information:
I have a transducer from SSI on my BrakeSmart controller PSI-2000 SANPO4
S/N 053332600 BV 600
Tag on wire harness
WO # 4423-14 009 62050187
Above number were the best I could make out.
Where can I buy a replacement? Bob
This mail is sent via contact form on SSI-Technologies, Inc. http://www.ssi-sensors.com/wp
I have NOT followed up on the info as mine is still working. Bob
Denny___Jami
I have one that has a bad case but I won't be back to my home base until next week. I had it on a 2000 F350.
Denny
2013 F350 SC DRW 6.2 V8 4.30 gears Air Lifts
2003 HitchHiker Premier 35FKTG 215/75/17.5 Goodyear G114 Tires
