Bullet 269rls with F150...Need your thoughts...New to this
poppabrown
I have been looking at TT's for some time now. My wife and I like the rear living setup. I drive an F150 and the yellow sticker in my door jamb indicates the max passenger and cargo weight is 1722. I added a tonneau cover to my truck that weighs about 120. After accounting for passengers and what I think we will have in the back of the truck, we have about 850-900 pounds for the trailer tongue weight.
We almost purchased a Jayco 27RLS, but the trailer dry weight was 6800 and hitch weight was 725. The max loaded weight of the trailer was around 8600. When I did the math, it didn't look like it would work. All of these dealers ONLY look at the max trailer tow weighting on the truck. They look at me like I am crazy for wanting to stay within the limits set on the truck.
We looked at the Keystone Bullet 269RLS this week. It is similar in setup to the Jayco, but it weights significantly less. The hitch weight is 585 and the dry weight of the trailer is around 5,200 pounds. The max loaded trailer weight is around 7500 pounds.
Two questions. Will my F150 be OK to haul the Bullet? Does anyone have any feedback on the Bullet 269rls?
Thanks for any responses.
5 REPLIES 5
Terryallan
Seems to me. You are good to go. As long as you don t want a golf cart in the bed
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
poppabrown
mbopp wrote:
Crew cab? How many passengers are you hauling?
I think it's doable but your tongue weight will go up after adding propane and a battery (or batteries.) And the real dry weight is probably 400# more than the brochure weight. You'll be closer than you think on GVW and rear axle weight. Power-wise you'll be in good shape, my EB has 3.55 towing 7,000# and I'm happy with the power.
We will almost always only have two passengers when we camp. We will occasionally have a third person, and we will be very close, if not over, when the third person is with us. If that is a problem, then we will only take it with two people and maybe drive a second car.
mbopp
2019 F250 XLT Supercab
Just DW & me......
poppabrown
Terryallan wrote:
You should have no problem with the bullet. Provided you have the right gears You did not say what your towing capacity is. Both payload and tow cap are required. Higher gears 3.31, 3.15 and such are not for towing I have a 150 with 7350 giver Has 3.73 rears, and 5.0 motor. That = 9300lb of tow cap. IF you have that much tow cap You will be good to go. My TT is 4800 dry. And 7400 giver. My 150 tows it great.
The trailer tow capacity definitely isn't an issue. I have a crew cab with a 3.5 EB and the max trailer tow package. Gear ratio is 3.55. The truck is rated to tow 11,500 pounds.
Terryallan
Terry & Shay
5.0, 3.73
Lazy Campers
