โSep-03-2016 03:34 PM
โSep-14-2016 06:06 PM
sch911 wrote:
The air dam is to assist in low speed stop and go traffic cooling. It's there to stop hot air from the engine box from recirculating back into the condenser and radiator. They have no affect on helping cooling while driving down the road.
โSep-14-2016 03:41 PM
โSep-14-2016 12:15 PM
JIMNLIN wrote:
Our older trucks didn't have a air dam. The result was heat would pack up in the engine compartment.
The lower air dam creates a low pressure area under the engine bay which allows a better air flow through the radiator to flow through the bay and on out the bottom.
I found out the hard way on a 3500 DRW chevy when the dam was broken off hauling cattle out of a pasture. The result was a hotter running 454 at interstate speeds.
โSep-14-2016 07:43 AM
โSep-05-2016 03:58 AM
โSep-04-2016 06:45 PM
BB_TX wrote:
Interestingly, this article from GM does not mention any thing about cooling related to air dams, only aerodynamics.
โSep-04-2016 04:24 PM
Huntindog wrote:
Over on the Automotive air conditioning forums, they sure think that the air dams are important for increasing air flow thru the condenser.... (And since the radiator is right behind it, then it has to increase airflow thru it as well.)
โSep-04-2016 03:59 PM
โSep-04-2016 03:34 PM
Muddydogs wrote:Bob Barrett wrote:
Just wondering if some of you have an opinion as to whether an air dam serves a purpose, especially when towing . I have an older 95 Silverado that seems to have alot of heat that builds up in the engine compartment. The gauge reads normal , and i have added a tranny cooler, but not an engine oil cooler . From what i can read the air dams channel some of the air into the radiators and condensors for AC . Most of my camping destinations are within 60 miles , once a year a beach trip that is 140 . As i build up a little more experience we plan to venture a little farther
Bobby Barrett
05 Zepplin 28 ft tag
So your temp gauge reads normal but there seems to be a lot of heat build up in the engine compartment? You do realize that your engine is running around 200 degrees, made of aluminum and metal as well as being surrounded by metal right? Your engine compartment is going to be hot once all that metal warms up.
The air dam has little to nothing to do with cooling as it's designed with the rig's aerodynamics in mind. Air dam's are designed to reduce the drag under the vehicle by forcing air down to the ground reducing air drag under the truck. So actually an air dam might cause the engine compartment to be even hotter as its forcing air away from the underside of the compartment.
โSep-04-2016 02:37 PM
JIMNLIN wrote:
No use being snarkey ...... I sure don't know more than GM engineers but I do know they help improve air flow through the engine compartment at highway speeds and do little in low speed driving such as in city type traffic. We are talking about working trucks and towing duties.
Radiator fans were once controlled by engine rpm now most are done electronically.
Low speeds/low engine rpms/city traffic the fans work as engine temps rise such as sitting in traffic or pulling a trailer up a steep grade.
Get out on the highway at high speeds and the fans shut down as the air flow increases.
A google has lots on the subject of the lower air dams on our trucks and what they do.
โSep-04-2016 01:46 PM
โSep-04-2016 10:43 AM
Actually the air dam does little at low speeds around town/city traffic.....thats where the trucks cooling fan(s) come to play.
The lower air dam creates low pressure under the engine bay at speed allowing better air flow through the engine bay and on out the bottom.
Some years back one GM truck forum had pics and diagrams of air flow through the radiator and out the bottom of the engine bay with a without the air dam on trucks at various speeds.
โSep-04-2016 09:14 AM
โSep-04-2016 05:46 AM
