camper shell
jay_b
Hello everyone,
Newbie to travel trailers just bought my first one have a problem who would have thought.I thought i would ask some people who might know what to do and how to do it.I have a travel trailer that when I tow it the shell separates from the frame in the front.It does have some water damage in the front storage area, but the bolts in the flooring seem to be firm.Any and all input would be helpful kids are itching to go camping but want to be safe.palomino Thoroughbred 01
14 REPLIES 14
sacmarata
If yer correcting someones grammar so you can better understand the point or question they are posing then it's perfectly fine. If your correcting it for any other reason yer just a dork nozzle and come off as a condescending jerk.
Have we gotten so intolerant that we can't even allow poor grammer without being condescending? ...and YES, it is VERY condescending. Teachers are supposed to demonstrate practical life skills as well as Reading, Writing and Arithmitic. I would submit that treating others in a non condescending way is much more valuable in life than proper grammar.
Now, to yer question. The known water damage is VERY likely to be worse than you expected. I would highly recommend a complete investigation. Look in storage areas, under vinyl, under seats, cabinets, beds, etc...
Moisture is our enemy!
Dork Nozzles are not 🙂
jay_b
Well the whole floor is shot going to put a new one in:S
westend
You may be able to diagnose and inspect any bad framing by using a "jacking post" and a bottle jack. This will also come in handy when replacing the framing. What I do in that regard is to make a "T" with 2x4 lumber, the top cross piece is long enough to span three ceiling joists (approximately 36"). The upright is long enough so that a bottle jack and plywood can be put underneath the upright for jacking. I also attach a diagonal brace from the upright to the top cross piece for stability.
Don't get too crazy by applying too much pressure with the jacking post. It's possible to detach the roof or separate the wall with one of these.
Good luck and, if you can, post up some photos for better advice.
'03 F-250 4x4 CC
2012Coleman
jay b wrote:
Yes I understand the way I write is not correct sorry.but you guys are great, looking forward to making new friends live,love and learn. Don't worry I've got thick skin (lol)
Good - your going to need it around here. And since others are being so helpful, let me point out the ignore feature of this forum. Simply click on their user name link and click block this member. It can be very useful. Good luck grtting your issue sorted.
2018 RAM 3500 Big Horn CTD
dannytas
It would serve everyone well to "answer" the post rather than "criticize" it's structure.
2014 Keystone Springdale 202QBWE
1998 Dodge 1500 Club Cab, 4x4, 5.9 magnum
DW-Lynn
BigDog-Kelley
LittleDog-Kroozer
LittleCats-Pokie and Dottie
jay_b
ChooChooMan74
Bumpyroad wrote:
'tiredTeacher wrote:
Judging from the OP's post title, I thought he's refering to the camper shell on the tow vehicle.
Inaccuracy of expression leads to misunderstanding every time. Makes an old English teacher's brain hurt.
Teach
I think that he inaccurately expressed how the trailer top was raising up from the rotten front. but he has not come back to clarify anything.
bumpy
I wouldn't come back after you guys making fun of his English and Grammar. Yes, it was a tough read, but some people are not the best at that stuff.
Great American Anti-Towing Conspiracy
2015 Ram Truck 1500 Ecodiesel Tuned By Green Diesel
2006 Jeep Liberty CRD Tuned By Green Diesel (Retired to Daily Driver)
2015 Rockwood Roo 183
Stop on by and read my Camping Blogs
Nights Camped in 2015 - 19 and Winterized
Bumpyroad
Teach
bumpy
GrandpaKip
Have a strong friend stand inside at the front and push on the ceiling. Look around outside to see if anything is happening.
Good luck.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
_tiredTeacher
Teach
Wright and Penny
2010 Tundra 4X4
2014 Rockwood 2604WS
"Life is a cruel teacher. She gives the test first; the lesson then follows."
Bumpyroad
Francesca Knowles wrote:
Welcome to the site, and here, for your use, I'm donating some things known in many quarters as "periods":..............They're commonly used to indicate the end of one thought/sentence and are usually followed by a space, after which a whole new sentence/thought/point begins. Hope you find them useful! And by the way; each new thought/sentence is usually capitalized. Helps as a heads up to the reader...
Now to your problem, as well as I can parse it: .
should also have donated some s p a c e s .
bumpy
ChooChooMan74
You have an '01 Palomino Thoroughbred and the body of the trailer is separating from the frame? Sounds like it has more water damage than you can imagine.
westend
The framing inside the walls has rotted away from the floor. If you hit a big enough gust of headwind when transporting, it will be easy to see because the deck will be hooked up to your truck but the shell will be laying on the road.
'03 F-250 4x4 CC
Francesca_Knowl
ON EDIT:
This English Major would like to thank the O.P. for the threadstarter edit which makes very thorough use of the above-donated punctuation.
Go to the head of the class, O.P.! 😉
If the shell appears to be separating from the frame in spite of firmly attached bolts, clearly new points of attachment must be found. Those bolts aren't holding anything but themselves on if the trailer shell is moving around while the rig is in motion.
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
