Camper Tie Down Extension
LA48340
Making my own frame mounted tie downs. What is the recommended extension length outside the body side vertical plane. thanks.
2 REPLIES 2
ramses355
I have Torklifts on a Lance 825 , sitting on a SRW GMC 2500. Torklift gives you two sets of holes to choose from. I think if you set the attachment plates directly beneath the camper attachment points you should be OK
GMC 2500HD EC, Lance 825
Kayteg1
On my dually the ties stick out slightly past 1/2 of outer tires.
Fastguns should goo with some angle towards the truck frame, so measure your camper width and deduct about a foot for the spread.
