โMay-09-2016 01:37 PM
โMay-15-2016 07:06 AM
โMay-15-2016 05:42 AM
โMay-09-2016 09:27 PM
โMay-09-2016 09:16 PM
Hunterred wrote:Since he has a valve that allows filling the tank the gravity fill doesn't have to be installed. I have a similar valve and have never used my gravity fill.
This sounds so bizarre to me. Since when do trailers not have a full tube? That's the only way we fill our trailer, couldn't imagine not having one?!?!
โMay-09-2016 09:10 PM
UrbanNomads wrote:Adding a small amount of liquid through the vent should work but not for filling the tank. When you attempt to fill the tank with the vent where does the air go with the vent blocked by water?
A possible solution that I found in the manual is in the sanitizing the water tank section. It states that with the model I have I can pour the sanitizing solution in through the vent hole. So I would assume that I could gravity fill through the vent hole also.
โMay-09-2016 08:41 PM
โMay-09-2016 03:48 PM
โMay-09-2016 03:19 PM
โMay-09-2016 01:57 PM
โMay-09-2016 01:52 PM
โMay-09-2016 01:50 PM
โMay-09-2016 01:47 PM
โMay-09-2016 01:45 PM
โMay-09-2016 01:40 PM
