Cargo box VS Solar
anutami
I've decided to use a cargo box and wanted to get different opinions if it is possible to mount a solar panel on top of the box to elimate the "shadow" effect on my panels. The box also opens up on each side So I could tilt the panel to get it in the right direction to the sun.
First option: will this cause a major issue with my solar panels casting a shadow
Second option
Third option: just go with the shadow effect since it is a losing battle anway
Fourth option:
Mount the panels on the cabover portion of the TC. I am hesitant to do this because
1. Need to drill more holes again into the roof
2. Putting more weight over the cabover area.
3. wires laying exposed on the roof
2001 Ford F350 LB Diesel 4x4 CrewCab Stick
2015 Wolf Creek 850 Thermal Pane Windows, Oven, Reinforced Anchor Bolts, 200w Solar, Torklift Tie Downs, Fastguns, Stableloads
16 REPLIES 16
jimh406
Park where you won't have a shadow.
Dakota98
Using the existing frame work that you've already installed, raise the panels to the height of the A/C & cargo box with additional frame work.
Just a another thought.
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
