I have done excactly as you are proposing..
My only suggetion is to not stop at 15s. Go all the way to 16s. That is where I eventually ended up. 6s gives you the best possible selection of QUALITY tires.
You will of course need 16" rims. They are normally 6 lugs, so 6 lug drums will be needed. They are suprisingly affordable. they come with new bearings, so if you do it at bearing repaking time, it makes it much easier labor wise... No need to clean all the old parts, just lube up the new stuff and install.
So in a nutshell... going from 14s to 15s is good.. but the tire selection isn't a ton better.
16s is nirvana. That size is used on millons of pickups, so the market is huge. The tire manufacturers have responded with MANY choices.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
