ls1mike wrote:
Hey All,
I have a 2012 Passport 3220BHWE and was looking at going from a 14 inch tire to a 15 inch tire or 205 75 R14 to a 215 75 R14.
Thoughts? Concerns?
Thanks!
X2 on Maxxiss if you go 15 inch. If you go to Les Schawb don't let them talk you into the brand they carry (like what happened to me). Go to Discount tire they might have to order and they are more money per tire but worth it. Yes, they have failures just like other brands, just not as many. Also go with steel valve stems.
But first make sure they will fit. Not only in diameter but also suspension wise, like when you hit a bump. Then have you given any thought to your spare?
On a post here somewhere somebody mentioned you can get Maxxiss from Amazon (to your house) and take tire and wheel somewhere to be mounted.
Personally, I thought 14 inch has more options than 15 inch. Didn't know 14's were also limited.
At any rate don't let Les Schawb tell you Maxxiss has been on back order for 6 months.
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
