Cleaning fresh water tank after winter.
Spappy
Anyone have any suggestions on cleaning the fresh water tank? I would like to do that as part of my de-winterizing but have found very little info. I remember reading somewhere about using bleach but won't that degrade the tank over time? Anyone care to share their process for rinsing/cleaning/sanitizing after winter?
Thanks,
Spap
15 REPLIES 15
Spappy
Thanks again for all the answers. Sounds like I heading to a full hookup site for my first camp. Thanks again! You are all great.
Spap
fallsrider
Interesting....I just went and looked at Arm and Hammer's web site about baking soda. They have a recommendation for "Deodorizing Your Camper's Water Tank" by dissolving 1 cup baking soda in 1 gallon of warm water. I may try this this spring.
fallsrider
Rjdreyer wrote:
First trip of the year is to a full hook-up site to flush and sanitize. After that, I can use state parks without F/H.
I agree. This is the best way if you can't do it at home.
Shadow_Catcher
I once bought a small bottle of what I was not sure to help kill the plastic taste in a new tank and did an MSDS sheet search and found a Much less expensive source. The kitchen cupboard. Last step for us is to us bicarbonate of soda to de-taste and additionally clean.
Alfred622
My comments would echo those from Sandia Man. That is the exact process we do also and it seems to work fine for us. I use Clorox bleach as you can smell it when it comes out of the faucets. Some other types of bleach are nearly odorless which makes it more difficult to run the water till the bleach comes out.
We also use our fresh water tank for drinking and food preparation so having it clean is important to us.
Alfred
2005 Sightseer with Workhorse, ReadyBrute Elite towing 2003 Honda CRV
Map below shows states where we actually camped.....
westend
Bucky Badger wrote:
Spappy wrote:
Thank you all so much for the information. It's very helpful. One final question if I can. I can not bring my TT to my house as the slope, angle, length of my driveway won't allow it. Do you typically do this at the CG with trips from water to dump station or is there another place you typically do it?
Thanks so much,
Spap
Could you do it in the street?
Technically, you probably could with no ill effects since the bleach dissipates quickly in air and the rest should just be water.
Unfortunately, in most cities it is illegal and you stand the chance of someone reporting you and getting a citation. It also looks really bad since no one observing knows what you're dumping.
I'd suggest to take your RV to a dump station and remove the bleach and water there. If the dump station has a potable water supply, you'll be able to rinse to your heart's content. If not, carry some additional water for a rinse.
'03 F-250 4x4 CC
Rjdreyer
Bucky_Badger
Thanks so much,
Spap
2010 F150 5.4, 3.55, 4x4, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
and
2009 Nomad 3980
Tom_Diane
Thanks,
Spap
X 2 on the chlorine bleach. Also to you question on getting water. Generally campground have water available.
Depending how far I want to go, I would only carry 5 gal. or so. No need to carry a lot of weight. Enough water for a half a dozen flushes and hand washing.
Other wise I travel mostly with out water.
NanciL
Tnanks for that question and the answers.
We are heading to Flamingo in the Everglades NP in another week, and haven't used our fresh water tank in several years and were wondering the best way to sanitize it.
So thanks again
Jack L
Jack & Nanci
NanciL
So thanks again
Jack L
Jack & Nanci
Spappy
Thanks so much,
Spap
mlts22
To elaborate on the bleach aspect... I make sure to use plain Clorox (name brand, no added stuff), and then once the FW tank is full, empty it out through both the grey and black tanks. This kills odors in both, and also helps with odors in the sewage hose. After running that through, I like filling the FW tank part way, adding baking soda, draining that, then filling up the FW tank for real use/consumption. The baking soda does nothing to sanitize, but more of a taste/odor neutralizer.
Sandia_Man
A 1/4 cup of bleach for every 15 gallons of tank capacity is what is recommended by most RV manufacturers. During the de-winterizing process, we fill tank adding an appropriate amount of bleach, run water through system to sinks, toilets, showers etc. Let sit for an hour or so depending on severity, drain and flush with fresh water. Bleach doesn't stay in system long enough to do all that much damage and if you don't overdo it in terms of how much bleach or how long it sits, damage is negligible.
We primarily use chlorinated city water from home in our FW tanks (always travel with at least one tank full) as we have run into some questionable water on the road, for us the process of sanitizing the freshwater tank is simple since the tank is pretty much clean already. We have even skipped sanitizing our FW tank a year or two over the 7 years of ownership of our current rig with no ill effects.
