Cleaning Fresh Water Tank
TXcampers90
Just purchased a 2003 Aerolite Hybrid Cub and wanted to clean the freash water tank before we use it. Suggestions please!
10 REPLIES 10
lbrjet
Hot water heater bypassed or no?
2010 F250 4X4 5.4L 3.73 LS
2011 Flagstaff 831FKBSS
Equalizer E4 1200/12000
3LittleDucks
Great tips, we'll have to give them a try!
2008 Nissan Armada TV
2007 Trail Cruiser 21RBH HTT
TOOBOLD
We put the 1/4 bleach for 15 gallons in the FW, but we go for a drive to let it slosh around. Open each faucet until I smell bleach and close each tap. Wait a few hours and then run until no more bleach smell.
TXcampers90
Thank to all for the help!
mhsmith
After emptying the FW tank by running pump to fill gray and black tanks, I refill FW tank with a mix of water and maybe 1/4 cup of baking soda. This helps freshen it and nuetrilizes the bleach. At this point, I run the mix thru the system, install my filter and ready for another season.
rockhillmanor
I periodically buy the the Thetford gray tank cleaner. It has something in it that also cleans the sensors.
Weekly I just buy a quart of any lemon cleaner from the grocery store and throw it down the drain. This works to keep it from smelling and my sensors always work.
I don't use bleach in any of my tanks because of the seals.
gbopp
Sanitize Fresh Water Tank
There are many sites that give the information on sanitizing fresh water tanks.
hmknightnc
old guy wrote:
use a clorox solution of 1/4 cup to 15 gallons of water. run pump with farthest faucet on until you smell the bleach. turn off and let set for 24 hours then drain the FW tank and fill with water and let run until you no longer smell the bleach.
X2. Might take a couple of complete rinses to get rid of the chlorine in the system.
minkos61
Fill tank with water, add a couple cap fulls of bleach, let sit, drain, refill tank and drain again should be good to go. Others may do it different but this is what works for me.
Ernie
2002 F350 Super Cab 4x4
2013 Starcraft Travel Star 274RKS
Weekend home to Ernie, Gisele and the fur bearing kids Mya & Bear.
Teddie & Lexi will always travel with us in our memories.
old_guy
