โMay-04-2018 03:12 PM
โMay-04-2018 04:15 PM
Dick_B wrote:
Go to the hardware store and buy one of those plastic drain claws that has the teeth on it facing backwards. shove it down the drain and move it around and pull out the `stuff'.
Do the same at home.
โMay-04-2018 04:10 PM
โMay-04-2018 03:52 PM
โMay-04-2018 03:45 PM
donn0128 wrote:
Take the screen off and start picking the hair out. I usually have to do mine at least once a season. Needle nose plyers really help.
โMay-04-2018 03:43 PM
time2roll wrote:
I would first verify the tank is empty then use some liquid drain opener from Home Depot. I use the commercial grade black bottle. Let it work a couple hours or overnight. Repeat weekly until back to normal.
Otherwise something got past the filter besides hair and soap that will need to be removed by opening the pipe fittings.
โMay-04-2018 03:38 PM
โMay-04-2018 03:36 PM
MFL wrote:
Can you access the p-trap underneath, to remove and clean out? Mine is easily accessed from the pass through.
Jerry
โMay-04-2018 03:29 PM
