Concern with attaching bike rack to TT bumper
crispyc21
I would like to get a bike rack for three bikes that attaches to the bumper of my travel trailer (2010 Sprinter Select). I started looking at a few online but when reading some of the reviews, some people mentioned that after attaching a bike rack to their bumpers, the additional weight caused the welds to come apart and their bumper and bikes would break off the trailer. Is this a common thing when attaching a bike rack to the rear bumper? My bumper already has the spare tire attaches to the bumper. Is their anything that can be done to eliminate that from happening?
61 REPLIES 61
BurbMan
Bikes on the back of the TT are do-able if done right. If you use anything attached to the factory bumper, you will be OK with straps like dodge guy and others have used. Those straps take the load from the bounce so it's not flexing the bumper as much.
the other option is to have a hitch receiver mounted to the frame rails of the TT, assuming the frame is sturdy enough to accommodate the extra weight. This is not an option on most ultra-lights.
I tried the ladder rig for a while, but did not like the way it bounced also, so ultimately we went with a Yakima rack on the roof of the Suburban. Bike racks that go over the TT tongue are also a good choice. A lot depends on what kind of TT and TV.
tim_and_amy
Yea, I for one agree with the do not do it crowd. I ignored the comments here, bought the receiver and bolted it on top of the bumper. Threw two bikes on there and had someone else drive my rig while I followed. Even with two bikes you can physically see the bumper rotate due to the bouncing.
Do your self a favor, get on amazon and order a front hitch receiver for your truck. Worth every penny. And fords are easy to install, just remove four bolts, drill some new holes in the current bumper bracket and install. I love mine.
FYI, you can make one that goes over the tow hook too if you don't want to take your bumper off.
2012 Kodiak 300BHSL Ultimate with Fall Edition Package
2003 Ford Excursion V10 Sold!!
2005 Ford Excursion 6.0L Diesel
chracatoa
I just leave the bikes on the bed with a tarp (a friend's idea). I use a ratchet strap.
For small trips I have them on the roof. Overall weight can be a problem for my 1/2 ton.
2011 Toyota Sequoia Platinum 4WD 5.7L V8 (next one will be a 3/4, someday)
2012 Jayco Flight Swift 267BHS (5963lbs dry, 6850 wet)
Propride hitch (I had a Reese dual cam round bar WDH for 4 months)
Tequila
I contacted Northwood. They say 50lbs on the bumper, and theirs seem heftier than most. I guess the bike is going on the front of the truck or inside. my bike is 60 lbs (electric)
Community Alumni
Not applicable
I had the original bumper replaced with a new full-width tube made from heavier steel (about 1/8" thick). I opted for a Swagman model "XC-2 RV" bike rack which is supposed to be an RV-specific design. The bike rack included a bolt-on 2" hitch receiver for a 4"x4" RV bumper. I'm pretty confident with the setup, but I still lock a steel cable around the bumper and bikes to keep everything together should something give way.
Huntindog
I haven't carried bikes but, backing into a camp one time with my wife spotting for me... I could see in the mirror that she was shocked.. Told me you gotta come see this. I got out and walked to the TTs rear, and was shocked to see my spare tire was gone.:E No idea where it came off or what mayhem it might have caused.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
dewey02
Paul 61 wrote:
I got the travel tray from CW and modified it by using an old bike rack I had to put the bikes on the front of TT. Since the Ultra Lites can not take the frame flex with the bike bouncing on the rear bumper. With the bikes on the front over the gas tanks it appears to be rock solid no bouncing at all.
Did you mean the Trailer Tray?
Can you post photos of how you modified it with an old bike rack? Thanks.
RandACampin
These bike rack threads crack me up. I have had a ack on my rear bumper for years...no issues. As far as all the comments on bouncing, well this last trip we drove 100 miles to the campground on bumpy Georgia back roads. I have a Thule bike rack where the bikes hang fron the top bar. When we got to the CG I discovered that I had forgotten to fasten the top straps over the bike. The bike looked like it had not moved one bit.
The bike rack threads are a bunch of anectodal posts with little or no truth desogned to fear-monger. If you look a lot of the posters are just re-gurgitating internet myths.
Walk around the CG and start asking people with bike racks...I do and have yet to anyone tell me of a real-world problem.
HEY CHECK IT OUT!! http://www.rvingoutpost.com
Paul_61
Dodge Ram 2500 5.9 diesel
Rockwood 2608 WS 2014
MarkTwain
I went about four years carrying three bikes on a platform carrier attached to the steel bumper with a bolt-on hitch adapter. Worked fine. Bumper was welded at both the top and bottom edges. I have seen some bumpers welded maybe 3/4 up on the flat side and the metal flexes and breaks easily. Got some nice bikes a couple years ago and had a proper receiver installed (attached to the frame) for about $600. No more worries.
X2, why take the risk
MarkTwain
Cheap bikes!!!
I would not be particularly concerned about what might happen to your "cheap" bikes but rather, what damage might it cause to the back of trailer if it comes loose and what potential danger could I be creating for other cars/people behind me if the bikes broke loose:)
wmoses
Bigbird65 wrote:
These bikes are on my trailer but at the time of posting I had not been on a trip to judge the bike rack performance. This week we made a 3 day long camping trip to Cedar Hill State Park in Texas. When we got there the bikes were exactly like they were when we left home and same for when we returned home. I'm completely satisfied with the bike rack. I used a number of the small bungees to stabilize everything.
Thanks for the good feedback on the ladder rack. I already bought the small bungees and will be going to Tyler SP in early June with the bikes. Just checked out the website for Cedar Hill SP - nice lloking park. Never knew it had full hookups and they still have 117 sites available for next weekend meaning they can't be that busy ... yet.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Ed. | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra 1500 SLE 5.3L 6-speed auto | K&N Filter | Hypertech Max Energy tune | Prodigy P3
_
Bigbird65
wmoses wrote:
Bigbird65 wrote:
OK, as an alternative to the bumper mount, give me your opinion of the ladder mount. Specifically a Swagman 2 bike mount.
For some reason it would appear that not many people who post on these forums have experience with ladder-mounted racks hence the lack of response to your query.
The Swagman 2-bike rack is similar to the one I bought from CW (possibly the same design) and funnily enough my ladder looks very similar to the one in the picture you included. I guess if you are asking the question then that was not your picture.
Anyway I have not made my first trip with that rack yet so I cannot comment on performance. I can say that my ladder appears strong enough, and the loading on it would be less onerous than that on a bumper mount. The CG of the bikes are closer to the ladder and the ladder support points are more spread out so the load is "flatter" to the RV and more in shear. Should perform well. The trick is to properly secure the bikes so that they (a) stay on, and (b) don't damage each other or the RV.
I will post my results after I have actual experience.
2017 RAM 1500 Quad Cab 5.7L Hemi, 8 speed 3.21
2018 Winnebago Minnie 2250DS
PAThwacker
Our sub has 60" thule cross bars, can carry 3 bikes, and the 38" wide canoe . That is a an easy $800 worth of Thule racks or more. Carries a couple grand worth of toy$.
Id rather put bikes on a swagman.
2015 Keystone Springdale Summerland 257rl
Tow vehicle: 2003 GMC K1500 ext lb
Previous: 14 years of 3 popups and a hybrid tt
