Jun-03-2007 01:48 PM
Jul-05-2010 10:56 AM
Jul-05-2010 09:55 AM
Jul-05-2010 08:49 AM
Jul-05-2010 08:20 AM
Fisherguy wrote:
I've used that caulking, just wasn't sure if you skipped the butyl which is some kinda sticky stuff but tends to ooze outa the seams. I think most people use butyl and caulk it later, but I'm not sure what the recommended pocedure is? Is the trailer a hard wall or alum skinned?
Jul-05-2010 07:57 AM
Jul-05-2010 07:27 AM
Jul-05-2010 05:58 AM
batman99 wrote:
This last weekend, I removed 3 windows from my wife's TT\s windows, applied some RV Sealer / Caulking around them and re-installed. The stuff I used is: - Click Here -
If wondering, the windows are NOT currently leaking. Just a proactive mod to eliminate them from leaking in he future. Each visit, I plan t seal another 3 windows. Within 1 month, I'll have all windows "properly" sealed. Properly sealed the way each window should have been done at the factory.
Tip: Apply masking tape around the outside of the window (on frame on on trailer siding). The masking tape strips can be easly removed afterwards and eliminate "over spreading" of sealer material. Lesson learned on the first window...
If into proactive maintanence / mods, you may want to remove your TT's windows, apply sealer between their inner frame and siding walls, and screw them back down again. Very easy proactive task to perform...
Jul-04-2010 09:50 PM
Jul-04-2010 08:58 PM
TURK2500 wrote:revrnd wrote:
I'll be finishing up a dual battery setup on my trailer this weekend....snip
Are you using 6volt or 12volt batteries? What amp? Series or parallel circuit? Post some pics of your finished system.
I'm looking into a possible dual battery setup with my TT as well, but want to maximize amp output with a dual setup..
Turk2500
Jul-04-2010 08:53 PM
batman99 wrote:
- Installed 110/120V-30A Surge Guard (hard wire) version. Surf:
- Click Here 1 -
- Click Here 2 -
Jul-04-2010 08:52 PM
Jul-03-2010 07:10 PM
Jun-30-2010 10:19 PM
Jun-30-2010 08:00 PM
Jun-29-2010 05:47 PM
welsteach wrote:
I just added an Adjust-a-Shower rod by Stromberg-Carlson. I can now move my shower rod into the tub with a push of a finger (creating more room in the tiny bathroom) or outside the shower (creating more shower space in the shower itself). It was a pain to install (would be much better with electric drill), but WELL worth it. My shower last night felt almost luxurious. It is similar to the bent shower rods in hotel rooms, except that it can move in and out. It is heavy duty metal, not plastic, which I thought it might be. I would recommend it.
