Jun-03-2007 01:48 PM
Oct-24-2010 04:05 PM
Oct-24-2010 02:27 PM
technoholic wrote:
We bought our TT used. The original booth style dinette had been removed and replaced by one that was cobbled together with 2x4s and plywood. It had to go. After removal, the
Oct-24-2010 07:25 AM
Oct-21-2010 04:37 PM
technoholic wrote:
We bought our TT used. The original booth style dinette had been removed and replaced by one that was cobbled together with 2x4s and plywood. It had to go. After removal, the walls and floor where pretty beat up. The walls were patched and new vinyl wallpaper applied to the bottom half. The floor was patched and a carpet remnant installed. Lastly, a new dinette table and chairs were brought in. We like the way it turned out and it was actually less expensive than buying a replacement RV dinette booth.
Oct-21-2010 01:32 PM
Oct-20-2010 01:33 PM
Oct-20-2010 01:18 PM
Oct-08-2010 08:30 AM
Sep-16-2010 06:36 AM
Sep-13-2010 11:49 AM
Sep-12-2010 08:01 PM
Sep-12-2010 02:00 PM
Sep-12-2010 05:37 AM
BamaGram01 wrote:
Headboards I made by getting a sheet of insulation and covering with batting and fabric. I also monogrammed some pillow shams to make the bunks look pretty since they are visable at all times. I also sewed some fabric and velcroed it to the side and bottoms of the bunks to cover the ugliness
Sep-10-2010 08:21 PM
Sep-09-2010 08:09 PM
Poppy & Nana wrote:mach8274 wrote:Poppy & Nana wrote:
Mach8274.................mach8274 wrote:
Flag pole
can the flag spin all the way around without hiting the front of the trailer..... and how did you mount it to the tongue???
No, the flag does not spin. It is stationary. It is mounted with custom brackets I made out of aluminum angle and u-bolts. The u-bolts mount the whole thing to the tube on my electric tongue jack.
Can you give more details on the bracket???? Photos??? We have one that we need to put a steak in the ground and it spins 360 degrees but this looks very neat!
I don't have any close ups of the brackets yet. We are going on a trip with it next weekend and I can take pics and post them then. Basically, 2 2 inch u-bolts mount the brackets to the tongue jack tube and 1 1/2 inch u-bolts mount the flag pole to the brackets. Then I used a pvc coupler to mount the flag pole to the pole on the tongue jack. I secure it with a quick release pin.
