Costco has a pretty small 6000 btu AC now
Jfet
I bought one and am going to see if I can mod it to work just venting from the back for a in-cabinet side wall installation. It is very very tiny and $139. I will let you know how it goes.
37 REPLIES 37
69_Avion
Nice installation. I'm glad that it is working out.
Ford F-350 4x4 Diesel
1988 Avion Triple Axle Trailer
1969 Avion C-11 Camper
dogtalker
I really appreciate your response.
Thanks again
Jfet
It is pretty close to the same as my mock up, except I didn't end up sloping in the sides toward the front of the AC and just made them 90 degree box shaped. I bent all of the aluminum on a $50 harbor freight bender.
I taped strips of paper in various places on the vent to watch the airflow and it does blow and suck in the correct areas as it should. I put some fiberglass screen on the inside of the outside vent grill to keep bugs/spiders out. This does not seem to impede the airflow. I attached the screen with dobs of JB weld. Dobs might not be a word since it is underlined in red. Am I babbling yet? I purchased the outside vent grill at either Lowes or Home Depot. If I had pants on I would go outside and measure it. Your dimensions sound right...you just want the vent to be large enough side to side to allow air to flow in both sides so it can be blown out the front.
Here is a picture from the inside without the vent cover on to give you an idea of the ducting. Note that before I added the cover I taped the seams of the shroud with a rubber type tape (like eternabond or something?) so if water blows in from the outside it will just collect in the pan. Oh yes, the bottom of the shroud is made up of an aluminum pan I bent up and sealed the corners with JB weld to make a water catch if the AC's condensation overflows. I have a sponge in each side to absorb the water and wick it up into the air where the ducting action will cause it to evaporate and assist in cooling the unit. Did that make any sense? So far I have not seen the water overflow the actual Danby pan, even in the humid NW.
dogtalker
Hi Jfet
I'm using your mock up as a guide to installing my Danby ac unit in my camper van. Please let me know if the shroud you added recently is exactly the same as the way the picture is of the mock up.
As far as the furnace vent you show is it the same as an air return vent like this
http://www.amazon.com/White-Return-Grill-Vent-Opening/dp/B00CGPQJB6/ref=sr_1_fkmr2_1?ie=UTF8&qid=1406731273&sr=8-1-fkmr2&keywords=14+x+25+furnace+vent+with+louvers
Thanks for providing all the information you did showing how to set up the window ac unit flush with the outside of your camper.
mkirsch
Nomad II
Nomad II
Dam(n) Sam, that is one wicked cool solution!
I haven't sold my 6000BTU window unit yet. If I can find a convenient place to put it in my TC, I might go with this solution yet.
My portable unit is a godsend in hot weather, but takes up floor space, needs a 2000 Watt generator, and is clunky to deploy.
travelnutz
Jfet,
Since the A/C was so cheap and it's a specific size and you have custom made all the shrouds. cuts, and finish trim etc for it, I go buy a second one right away before they are gone and store it as a replacement on hand for the 1st one if it should burnout or fail. Very cheap insurance and simple to exchange out without any alterations needed.
A superb CC LB 4X4, GM HD Diesel, airbags, Rancho's, lots more
Lance Legend TC 11' 4", loaded including 3400 PP generator and my deluxe 2' X 7' rear porch
29 ft Carriage Carri-lite 5'er - a specially built gem
A like new '07 Sunline Solaris 26' TT
Jfet
Just an update on this little AC unit thread from last year. I built a shroud out of aluminum that directs the outside air into the side vents and blows the exhaust air outside. This allows the AC unit to be fully mounted inside on the side of the camper. On the hottest day we have had so far (90 degrees) it easily cooled the camper down to 67 degrees. I lined the outside of the aluminum shroud with 1 inch of polyisocyanurate rigid foam insulation. Eventually I will make a nice finished wood cabinet on the inside to cover the housing and just leave the front of the AC exposed.
69_Avion
unbob wrote:
Anyone using the 5,000 BTU Frigidaire Window-Mounted Mini Room Air Conditioner ??? Model # FRA052XT7. It draws 4.8 amps also. Only weighs 35 lbs. Only $119 at Amazon (with free shipping).
http://www.airforums.com/forums/f427/5000-btu-hr-ac-and-1-000-watt-genny-91215.html
unbob
Jfet
Ok so through wall usually means the air conditioner has been designed to pull in air through the back of the AC and vent the air out of the same back. With our ducting, we are just doing the same thing. Here is a diagram of the airflow in the mockup I did which seems to work pretty well (tested with paper streamers to map the vector field of air flow). Obviously blue represents incoming air and red is the exhaust air that has passed through the condenser.
edit: the top two vent louvers on the external grill I used are also above the level of the Danby AC so some air can flow in there and across the top of the AC then down into the unit. The AC is 12 inches tall and the grill is 14 x 25.
unbob
Jfet wrote:
manual is here: http://www.danby.com/cms/documents/pdfs/en/DAC6010E_DAC6011E_EFOM_%28DM%29.pdf
current draw is 5.4 amps on nameplate
Yup, that is correct. Thank you!
Jfet
unbob wrote:
Anyone know the amp draw on the Danby DAC6011E 6,000 btu unit?
I have horizontal sliding windows in my Bogfoot camper - any reason I can't install this unit in my window?
Normally this time of year I'm in a much cooler spot but now stuck in an "emergency" situation in a very hot and humid spot for the next 2 months or longer - what a bummer!
Like I mention, a nice cheap small AC with a full digital thermostat, timer functions and remote control. Some of the slightly cheaper models only have a 1,2,3 speed knob.
unbob
There's also the Danby DAC5111M 5,000 BTU unit here
Found this statement in the product manual: This 115V air conditioner uses 4.8 or less nameplate amps and may be used in any properly wired, general purpose household receptacle.
Product manual also states: NOTE: THIS UNIT IS NOT DESIGNED FOR โ€œTHROUGH-THE-WALLโ€ INSTALLATION. Pardon my ignorance, but what does that mean? What's the difference between a "window" mount and a "through-the-wall" mount? Keep in mind this will be installed in a TC.
unbob
