โJun-08-2013 07:23 PM
โJun-22-2013 06:50 AM
โJun-22-2013 06:43 AM
โJun-21-2013 09:00 PM
mkirsch wrote:
I think you'll be disappointed with the performance if you block the sides in.
I believe that window units suck air in through the sides and blow them out the back, or vice versa.
At the very least you need to build in some venting around the sides to allow air in/out.
Ideally for this application, you'd want a sleeve unit, which is designed to have the sides buried in a wall. Unfortunately the public can't purchase small 5000-6000 BTU sleeve units that I've been able to find.
โJun-21-2013 03:25 PM
niftypkg wrote:
I installed a small A/C at floor level near the door in my Sunlite. In this spot I suppose there was an access door for a battery. I bought this camper because the former owner started the project and included the A/C. The unit starts but after about 15 minutes the compressor cuts out. Maybe several reasons: The shore line was only plugged into a house circuit; There is not enough ventilation in the truck bed behind the fins and the compressor overheats then the thermo protection circuit opens. After 15 minutes the compressor restarts (The blower continues to run). ( Could be the compressor was not getting enough voltage?)There is a circuit breaker GFI on the units OEM cord which is plugged into a 20 amp camper outlet. That 20 amp converter camper breaker did not pop. In fact no breaker popped. Thought my experience might help others. Any suggestions?
โJun-21-2013 01:00 PM
โJun-21-2013 01:29 AM
โJun-20-2013 09:15 PM
โJun-20-2013 08:53 PM
~DJ~ wrote:
There were some good threads on how to install window mount AC but could not find them.
CB
Channel 17Redneck Express
โJun-20-2013 08:20 PM
โJun-09-2013 07:38 PM
69 Avion wrote:
I bought a Frigiaire 5000 btu model that runs very well off of my Yamaha 1000 watt generator. It has enough power to run the AC, charge the batteries and run a computer. The 5000 btu AC will cool my Avion C-11 in the middle of the summer, in Phoenix, as long as it is in some shade.
โJun-09-2013 06:52 PM
โJun-09-2013 03:51 PM
โJun-09-2013 03:06 PM
โJun-09-2013 01:40 PM
โJun-09-2013 09:18 AM
ticki2 wrote:
So , what is the make and model ? I don't see anything like it on their web site . I have seen quite a few in the 5-6000 range but for what I have in mind dimensions are critical, always looking .
