โJun-29-2020 08:44 PM
โJul-01-2020 12:21 PM
โJul-01-2020 05:19 AM
atrerice wrote:
I'm leaning towards the GFlex epoxy since the first repair I made was with the PlastiMend. Now, that was not with an ABS sheet though. If I use the GFlex, I would embed some fiberglass mesh in it.
โJun-30-2020 04:48 PM
โJun-30-2020 12:00 PM
atrerice wrote:Yes the sheet was extra from Plasti-Mend. I cut the sheet then used a heat gun to get the curved shape just right before making the repair. All corners rounded etc. Used lots of the adhesive and had a jack ready to gently hold in place. Need to work pretty fast to get it set just right. Next day slathered more on top and especially around the edges of the ABS patch to have everything smooth and stress free.
That's right a this is a black ABS tank
I do see that Plastimend has a kit that comes with some sheets of ABS. Is that similar to what you did? The spot I will be repairing is right under where the dump pipe connects to the tank.
โJun-30-2020 04:37 AM
โJun-30-2020 03:24 AM
โJun-29-2020 10:11 PM
โJun-29-2020 10:02 PM
โJun-29-2020 09:50 PM
โJun-29-2020 09:36 PM
