โJun-26-2020 01:48 PM
โJul-01-2020 11:40 AM
mountainkowboy wrote:mbloof wrote:mountainkowboy wrote:
Upper stableloads, Bilstein shocks, and load range "E" tires.....4,500lb TC loaded and ready to camp. 12 years and 55K+.
I was looking for unmodified trucks my friend. ๐
- Mark0.
stock it was fine but sat dead level.......this is completely stock.
โJul-01-2020 11:19 AM
- Mark0.
โJun-30-2020 06:01 AM
โJun-30-2020 05:26 AM
wnjj wrote:
For clarification, do you consider shocks to be a modification or not? They replace a stock part with an equivalent or better but since they are also a wear item you could consider them just replacements. The same question goes for the tires I suppose.
As I mentioned above, I did replace the shocks and eventually the tires but with no major notable difference with the shocks and the tires were the same size and load rating as the worn out OEM tires.
โJun-30-2020 03:19 AM
โJun-29-2020 09:06 PM
โJun-29-2020 08:15 PM
โJun-29-2020 06:44 PM
โJun-29-2020 06:42 PM
โJun-29-2020 04:15 PM
โJun-29-2020 04:09 PM
โJun-28-2020 03:12 PM
โJun-28-2020 11:59 AM
mbloof wrote:Wow, you kinda lost me. Maybe you were trying to confirm the obvious? Regardless, hope you find the info you're looking for ๐otrfun wrote:Actually the size and model of camper is meaningless.
mbloof, in the context of your question, isn't knowing the weight/size of the truck camper also important?
I think it goes without saying, the heavier the truck camper the more likely someone will modify their 1-ton truck to haul it.
The lighter the truck camper the less likely someone will modify their 1-ton truck to haul it.
There's a massive difference between hauling a 1,500 lb. popup truck camper and a 5,000 lb. double slide truck camper.
As consumer trucks are a engineering compromise of use cases and while we would like to think that camper hauling is a 'large' use case, it is actually one of the smaller ones.
It is my theory that just about everybody makes modifications to their truck to carry a camper. (not including the required tie downs and optional extra 7-pin connector)
Given the world wide nature of this forum and the dismal responses of folks that don't modify their trucks, I'll claim that it is rare that a truck owner does NOT modify their truck for truck camper hauling duty.
- Mark0.
โJun-28-2020 11:29 AM
