Jul-20-2015 01:25 PM
Jul-22-2015 12:07 PM
Jul-22-2015 11:16 AM
Jul-22-2015 10:36 AM
Jul-22-2015 09:28 AM
Jul-22-2015 09:27 AM
fatboy66 wrote:donn0128 wrote:
Heat and speed kill most ST trailer tires. How fast were you going?
That's not what he asked.
Jul-22-2015 09:25 AM
Jul-22-2015 08:50 AM
Jul-22-2015 08:31 AM
4X4Dodger wrote:
I check my inflation with a gauge before I start from home or campground everytime. COLD. I inflate to the Maximum cold inflation marked on the tire. I also walk around my entire rig every time I stop for fuel or any other reason and one of the points I check is a visual on all the tires and wheels.
Jul-22-2015 06:57 AM
Jul-22-2015 06:53 AM
Jul-22-2015 06:16 AM
B.O. Plenty wrote:gmw photos wrote:Totally agree. Get rid of the junk tires!
Note to the original poster: everybody is beating around the bush here. Let's cut to the chase: junk the crummy ST tires, and do not replace them with yet more junk ST tires. Buy LT tires, and then go drive at normal highway speeds, and not worry.
Lets make it simple:
ST= junk
LT = good
EDIT: if those are the typical 205/75-14, then what I did was went to a 185-14 Kumho 857. This a commercial LT tire, in a load range D, that is marketed for trailer use also. Tire rack sells them. They work well.
B.O.
Jul-21-2015 08:20 PM
Walaby wrote:JIMNLIN wrote:
Good advice for anyone.
I would add the net search brings up all types of forums (RV and non RV) that use some type of trailer. Its not a pretty picture.
For all new folks I would suggest http://www.rvtiresafety.com/.
Roger has pages of LT vs ST in his blog. He eliminates lots of myth on the subject that we see on RV forum mostly.
Wow.. Just read some of Roger's articles. Very interesting, and at the same time, easy to get information overload. Bottom line from what I gathered, is there are a lot of variables that affect how a tire performs and just "blaming" brand"x", or "assuming" equal weight distribution across all four tires (in dual axle config)without valid information or facts can give you a false sense of security.
Reading his article on individual tire load/weight makes me want to re-weight my trailer at the local CAT scales. I've weighed it twice now, but I will probably at least get individual axle weight for the trailer itself. Not sure I can get individual tire weight. My travel trailer is configured how I intend on hauling (having just got back this weekend). So, at least, at a min, I will have individual axle weight and can make some educated judgements based on that.
All I can say is there are a lot of variables that contribute to tire failure. And I tend to want to believe someone like Robert, who has 40+ years of experience in the tire industry.
Mike
Jul-21-2015 07:38 PM
Jul-21-2015 01:31 PM
Jul-21-2015 11:33 AM
gmw photos wrote:
To the original poster, as always a tire thread has taken on it's usual life of opinions, arguments, etc. I would simply say: do your own research. Do internet searches for things like ST vs LT tires, ST tire failures, LT tire failures, etc. Look around over on the Airstream forums ( airforums ), there is a lot of lively discussion of it there.
I would also suggest you physically take a look at some dismounted ST tires and comparable sized LT tires, and see if you can "feel" the difference in the sidewall construction.
It's your money, and your trailer, so you need to make your own decision as to what might work better for your trailering situation.
Best of luck to you, and happy camping. See you on the road.
