Death of a D-max-not pretty or cheap
Greentreena
From a diesel site I visit:
stock D-max, 230 000 km (143 700 mile) They think an injector went and then it when to hell from there in 15 minutes!!
The turbo sucked up debris so it is cheaper to go find a complete engine rather than repair this one. Words of advise, if it starts running "funny", STOP!!!!!! This could happen to any diesel engine.
2008 Dodge Ram 3500 6.7 Mega Cab 4x4 SRW Laramie - Big & Black
Full delete, Torque Technolgies programmer, Sinister EGR delete
Hijacker Auto Slide/ P3
2006 Triple E Topaz 310RBXL
Wife, 2 kids (Murphy the dog - RIP friend)
24 REPLIES 24
jerem0621
64thunderbolt wrote:
Glow plug breaking will cause similar damage. A friend had this happen. Ford dealer r&r a new 6.4 reman long block $13K out the door.
So $22K is rape or BS.
LOL@13k like its chump change..
TV-2022 Silverado 2WD
TT - Zinger 270BH
Itโ€™s Kind of Fun to do the Impossible
~Walt Disney~
bmanning
larry barnhart wrote:
bmanning wrote:
Remember all of the 400 cummins that blew up in 05. Nothing is perfect.
chevman
HUH?? Enlighten me because I have an '05.:h
He's referring to some issues that popped up with Cummins ISL "400" engines.
Completely unrelated to your 05 ISB.
the point was nothing is perfect and problems happen to the best of products.
chevman
Agree with that 200%.
That's why I'm not brand loyal; IMO no one's produced the perfect* truck yet.
(My definition of perfect is basically 10yr/250k miles of maintenance only/zero repairs)
BManning
baking in Phoenix :C
-2007 Volvo XC90 AWD V8
4.4L 311/325 V8 6sp Aisin loaded
6100lb GVW 5000lb tow
-1999 Land Cruiser
4.7L 230/320 V8 4sp A343 loaded
6860 GVW 6500lb tow
RV'less at the moment
larry_barnhart
chevman
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
64thunderbolt
Glen
04 Tail gator XT 34' 5th wheel garage model
200w solar 2 GC2's 800w inv
Truma tankless WH
99 F350 CC DRW 7.3 ais intake, adrenaline hpop, JW valve body,
cooling mist water inj, DP tunes, 4" exh sys
trucool trans cooler added
2011 RZR 900xp
bmanning
chevman
BManning
-1999 Land Cruiser
6860 GVW 6500lb tow
Perrysburg_Dodg
Very well could have been an injector, if the injector comes apart the pieces will take out the valves, piston and cylinder wall right?.
Don
2015 Ram 1500 Laramie Crew Cab SWB 4X4 Ecodiesel GDE Tune.
45Ricochet
chevman
LOL
He won't link you to none, zip, nada so relax.
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
transamz9
chevman
2016 Ram 3500 Mega Cab Limited/2013 Ram 3500 SRW Cummins(sold)/2005 RAM 2500 Cummins/2011 Sandpiper 345 RET (sold) 2015 Sanibel 3601/2008 Nitro Z9 Mercury 250 PRO XS the best motor made.
larry_barnhart
chevman
chevman
prodigy
scanguage II
TD-EOC
TST tire monitors
FMCA # F479110
glazier
Complete Diesel replacement would be a lot of money OEM. I would just buy an engine with some miles from a salvage yard, there's thousands to choose from.
2017 Grand Design Momentum 328M
2015 Chevy 2500HD LTZ Duramax CC/SB/4X4
B&W Companion Slider
gmcsmoke
Seamutt wrote:
In pickuptruck.com read of a fellow that had his D-max replaced under warrenty, cost could have been $22,000. Diesel outside of warrenty like shooting craps.
because it's very common to see an engine failure after 100k in a modern diesel. :R
hammer21661
Seriously? 22k That is ridiculous I can see 10 or 12 for a new motor but WOW!
2018 Ram 3500 SRW crew cab long bed 4x4 diesel Lariamie 1-2018
2013 fuzion 322.8/25/2012
2000 Yellow Lab mix Dog, Earl,The One who gave me Unconditional Love picked up 9-12 or 13, 2001 till 2-7-2014 may he r.i.p.
Seamutt
45Ricochet
Glad it wasn't you OP but I agree, your photo is a dropped valve IMO.
But I do find the 6.7 PSD listed above interesting also. Guess they went from the 8 hole in the 6.4 to the 6 hole in the 6.7's :W Maybe they will work they're way back to the "zero" hole soon....
Bunch of ugly photos at any rate.
