โSep-20-2013 10:11 AM
โSep-23-2013 10:07 PM
fallsrider wrote:
I put new tires on our '05 Suburban today. Had the P tires removed, and Cooper Discoverer H/T LT tires installed. Now that my max. psi has gone from 44 to 80, what psi should I run in my tires for normal everyday driving? This is my daily driver.
The tire shop put 35 psi in them, but I'm wondering if that is enough. Maybe it is.
Then when towing our TT, what should I raise the psi to? I'm estimating our TT weighs in the 5,000 to 5,500 lb. range. Haven't had a chance to weigh it yet.
Thanks.
โSep-23-2013 07:30 AM
โSep-23-2013 06:30 AM
โSep-23-2013 06:18 AM
Old-Biscuit wrote:
When you changed out those 'P' tires with MAX of 44# did you check what the rims MAX pressure is?
Upgrading to a higher rated tire doesn't do any good if rims are not rated for increase
โSep-23-2013 04:17 AM
Thanks.
โSep-23-2013 02:26 AM
โSep-21-2013 01:21 PM
'15 Chevy Silverado 2500 HD
'18 Forest River Avenger :C "Dolci"
Kipor KGE3500Ti
CHECK OUT THE RV.NET BLOGS!!
โSep-21-2013 08:55 AM
โSep-20-2013 05:03 PM
smkettner wrote:Door says 30 F&B. I think that is too low.
What does the door say? Same size just LT?
I recommend ~40 with maybe 50 to 65 in the rear when loaded and towing.
Did they install high pressure snap in or metal valve stems? Regular are good to 65 max.
Check the wheel rating before you go much over 50psi.
โSep-20-2013 04:14 PM
โSep-20-2013 01:03 PM
โSep-20-2013 12:17 PM
โSep-20-2013 12:14 PM
โSep-20-2013 11:31 AM
