Dewinterizing
tmas
My new TT has been winterized with the pink antifreeze, how do I dewinterize before our first trip?
2009 Silverado Crew Cab 5.3L
2014 Salem 28QBXL
10 REPLIES 10
Spappy
I've seen it suggested here before and didn't see it repeated here, but a lot of folks say that their first trip of the year is normally full hookups, so they can flush and dump on site. I thought that was a great idea.
Thanks,
Spap
Boband4
Be careful using the HW heater rinse out wand. 2 weeks ago I used one and evidently had the pressure on the water faucet too high. Blew the wand right off the shut off valve that was screwed on the hose. Seems as though that was a one time connection because the wand would snap right back on but would also blow right back off when I turned the water back on. I felt lucky that the wand didnt shoot off the valve while it was in the heater. I think it could be pretty difficult to fish that out of the heater if it went all the way in. Bottom line is "learn from my mistake, keep the pressure low when using the HW heater rinse out wand."
ken56
We were newbies 2 yrs ago and the best thing I can tell you is to read ALL the manuals that came with your unit and gain an understanding of the systems in the trailer. De winterizing is easy but RE winterizing is vital to prevent damage from freezing water in the pipes and pump and you must be thurough and do it properly. Really, RVs are not all THAT complicated to understand how things work. Mostly, HAVE FUN WITH IT. As they say.... GO CAMPING!
dethrower
thanks for the quick response! Sure do appreciate all you guys and your opinions. It helps us newbies!
BarneyS
dethrower wrote:
When I winterized last year, I didn't have the hot water heater completly bypassed. Antifreeze got to into the tank. How should I rinse it out?
Take out the drain plug and get a water heater rinse wand to stick in the hole and turn on the water. I would let it rinse for several minutes because if there is any antifreeze left in the tank you will get foam out of the faucet.
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
kearlms
Just fill and drain and fill and drain. It should take care of most if not all of it.
dethrower
skipnchar
Our first camping trip often occurred before temperatures were above freezing. With previous RVs we would travel south until we reached appropriate temperature then in the campground we'd flush out antifreeze. With current trailer I pick a relatively warm day maybe a month or so of departure date and flush out system and leave the trailer plugged into 120 volt power with heated tanks keeping things thawed and ready for use. Also leave a small electric heater on in the cabin to prevent freeze ups in internal plumbing. It's really a little different for each RV depending on how it's equipped and what your storage situation is.
Good luck / Skip
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
coolbreeze01
Just use it. The pink will go away. Have fun.......
2014 Sandsport 26FBSL
sbowman871
Hook up a hose to your city water connection. Open up one faucet one at a time until the water runs clear. Do both hot and cold, inside, outside shower. Turn off the water to the TT. Put your hot water plug back in the tank if it's out. Un-bypass your hot water heater by twisting valves 180. Turn on at least one hot water faucet. Turn on water and your hot water heater will fill. Dump grey an black tanks before camping (optional).
2010 Everlite 29FK
2011 Ford F150 V6 Ecoboost Max Tow 3.73
Parkit 360
