Dicor self leveling lap sealant caused roof to ripple
Lacey999
I used Dicor SLLS on, what I believe is a TPO roof (white on both sides). Within a day of applying this, the roofing material rippled and lifted, even where it was applied on top of previous SLLS. I did this at the front end cap but still have the rear of the trailer that needs SLLS applied and want to avoid this happening.
What, if any, SLLS can I use that won't cause this? I panicked and removed the sealant thinking it was destroying the roof. I've since been told it will smooth out in time as it cures but that could take weeks given it being October in the Pac NW. I'm selling the trailer and this is not a good look.
8 REPLIES 8
deltabravo
Unobtanium wrote:
It sounds like the OP used self leveling Dicor on an Alpha Systems Superflex PVC membrane roof, which requires a specific sealant made by Alpha systems.
DITTO, I've had the same thing happen.
2009 Silverado 3500HD Dually, D/A, CCLB 4x4 (bought new 8/30/09)
2018 Arctic Fox 992 with an Onan 2500i "quiet" model generator
ktmrfs
Dicor on the info sheets will tell you that Dicor sealant on a EDPM roof WILL cause some " buckling" etc as the sealant cures and usually will go away. Part of the reason is the sealant has hydrocarbon solvents (naptha etc) that Dicor says will cause this to happen. That is why the say to never use such solvents to clean the membrane. I suspect the solvent in the dicor is controlled and designed to not cause damage but to aid in adhesion.
2011 Keystone Outback 295RE
Planeteer
I also had this happen on our last MH. Sealed up good, and smoothed out over time.
2021 Gulf Stream 197BH
Unobtanium
gwalter
I had the same thing happen. There are 2 types of TPO roof and the newer one with a smooth surface on the underside will ripple with Dicor 500 series. You need to use the Ultra Dicor and solvent to clean with before applying. I used this and no problems. There is a You tube video on how to tell the difference in type of roof you have.
2010 Ram 3500 Laramie
2021 Bighorn 3120 RK
B & W Companion Hitch
Air Bags
Huntindog
I have had this happen. It will lay back down over time.
Huntindog
100% boondocking
2 bathrooms, no waiting
17.5LRH commercial tires
Lwiddis
Iโ€™ve never heard of your issue. Was the temperature above Dicorโ€™s minimum for application?
NamMedevac_70
Since 2003 I have applied a fresh coat of Dicor liquid roof almost every year to my TT without any issues what so ever and no ripples. My roof is regular roof material and non TPO. Perhaps there is a special product for TPO?????
