Oct-21-2014 01:15 PM
Oct-25-2014 01:02 PM
FTF1Geocacher wrote:
Is there a newer status than a Newbie. Yep. that would be me. I just got on RV.Net and I just got my first ever TT 18 footer. I just got new Chinese 10 ply tires for her. I hope they will last for a while and be dependable on upcoming road trips.
Oct-25-2014 01:01 PM
Oct-25-2014 12:27 PM
Is there a newer status than a Newbie. Yep. that would be me. I just got on RV.Net and I just got my first ever TT 18 footer. I just learned how to winterized her. Never gone camping in a TT or anything for that matter so this coming Spring will be my very first to take her out. I just got new Chinese 10 ply tires for her. I hope they will last for a while and be dependable on upcoming road trips. I enjoy reading all your comments because I am learning a lot from you.
Oct-25-2014 10:17 AM
Oct-25-2014 09:30 AM
wincrasher65 wrote:CKNSLS wrote:TXiceman wrote:
I tell folks buying a new or used RV to check the tires. Refuse to deal on the Rv unless the Chinese tires are replaced with a quality tire.
Kne
In a 14" or 15" size you will be hard pressed to find a ST tire not made in China. Many RV dealers will not put a truck tire on a trailer.
I wonder why not? With all my questioning, and researching on some of the links provided, all I get is people trying to economize.
In that, I mean trying to determine the exact minimum tire you can buy for your application, without spending any more than necessary.
But when I think about it, I always go back to the fact that tires is the one place on an RV that I don't want to scrimp and would like some healthy margin. What's wrong with buying 100% more tire than you "need"? Other than the cost, I've seen absolutely zero information on why you would not want to put on a tire with much higher load ratings than you could get away with.
Tire Rack wrote:
Trailers will be more stable and pull better on tires designed specifically for trailer use. Since Special Trailer (ST) tires are constructed with heavier duty materials, they are tougher than typical passenger vehicle tires. This is a plus because trailer suspension systems are generally stiffer and less sophisticated than automotive suspension systems.
Oct-25-2014 07:03 AM
Kne
Oct-25-2014 06:57 AM
Oct-25-2014 01:07 AM
Kne
Oct-24-2014 10:28 PM
Kne
Oct-24-2014 08:06 PM
Oct-24-2014 01:50 PM
wincrasher65 wrote:
My new trailer is to be fitted with truck tires - I'm assuming 10 ply LT tires of some kind. It's a standard feature and not a request on my part.
What are the thoughts on doing this? The trailer GVWR is 7000 lbs, twin 3500 lbs axles.
My first thoughts is that they would be better tires than ST or trailer tires.
Oct-24-2014 09:09 AM
dodge guy wrote:jaycocreek wrote:
I've been towing since before Good Sam existed and in that time I have had one blow out pulling a RV. I never tow over 60 mph/always have my tires covered and use tire treatment regularly when I wash it and use it mostly over rocky washboardy roads.
I was at Les Schwab the other day and ask about this 3-5 year rule by the new RV clan. He looked at me like I was crazy but remember, this is a logging and ranching community. He basically said drive with caution and not like a bat out of heck and treat your tires like there supposed to be treated and they will last just fine without worry.
I agree.
Terrible advice! Sounds like simeone there needs to be brought up on how it is in the RV towing life.
Oct-23-2014 11:22 AM
I do know it's a 16" BF Goodrich, but I don't know the exact size.
I'm assuming also these go to 80PSI for that max load, so inflation will be important to hold down any bounce from running too "hard". The axles also have shocks, which should help alot I imagine.
Oct-23-2014 09:38 AM
Oct-23-2014 09:11 AM
rbpru wrote:
I guess from these 7 pages of posts, it is up to the individual to choose which Third World Nation they want to produce their tires.
Really confusing but I will be digging into the LT vs. ST, China vs. non-China, load range upgrading etc. in the next couple of years; so I enjoy these posts.
