Jan-30-2023 03:27 PM
Feb-01-2023 04:35 PM
Feb-01-2023 03:39 PM
Grit dog wrote:
Now we’re cookin with gas…..or diesel:…
We got the 20mpg HD gasser club, roflmao, you do realize that’s not a thing,right? Vs the diesel has been more expensive for 20+ years, also umm not true.
And the guy who “won’t chime in” but followed that statement with a paragraph of chiming in…
This is the makings of a good old fashioned geezer.net debate!
Feb-01-2023 03:31 PM
Feb-01-2023 03:30 PM
IdaD wrote:mosseater wrote:
I don't chime in on diesel vs gas. I personally don't see a need for ME to pony up another $10k for a diesel. My '22 F-250 Supercrew is quite nice with the 7.3. For those comparing peak torque 6.6 v 7.3 you may want to see when that torque curve comes in. About 1000 rpm for the Ford and about 4k rpm for the 6.6 to reach the same number. The 7.3 is a great combo with the 10 spd and has gotten about 20 mpg on decent highway, about 15 average. Around town and idling in 4 wd about 12-13, and 10-11 towing my 8000lb trailer. I'm very happy with it so far.
I suspect the 11.3 average MPG figure on Fuelly for the 7.3 in a Super Duty is a more realistic expectation most folks should have. The 10 speed certainly helps which is why it doesn't average single digits. I think my 2015 Cummins overall MPG average over 100k miles is about 15. A big gasser won't do as well as it regardless of the transmission.
Feb-01-2023 03:06 PM
JRscooby wrote:
I would still like to see side by each comparison, equal weights, displacement, gears, and wind resistance, diesel with exhaust brake to closed throttle on gas engine.
Feb-01-2023 12:48 PM
Feb-01-2023 12:36 PM
Feb-01-2023 10:29 AM
stsmark wrote:
In 2020 the TFL guys did the Ike with a 7.3 10sp. with 4:30 gearing. They used large living quarters horse trailer loaded to 16k. On the downhill it took 9 brake applications to hold their 50-60 test. On the uphill it did it in 8:47 secs which is close to perfect 60 mph constant. Trucks fuel meter said 2.2 mpg during the climb.
Same setup with GM 6.6 6 sp. did 10 brake and uphill was over 11 min. at 2.3 mpg.
Just an fyi.
Feb-01-2023 09:39 AM
Feb-01-2023 09:33 AM
mosseater wrote:8K is not much of a load. Gas is fine for that.
Feb-01-2023 09:30 AM
valhalla360 wrote:Huntindog wrote:
It is not suprising. Gas is cheaper right now.
I have been driving diesels since 2000. The price of diesel vs gas has swung back and forth many times since then. Twice there was a pipeline
problem and gas just wasn't availible. There are two constants. Gas propenents will always crow about how smart they were when gas is cheaper, and fall silent when it is not.... And diesel ALWAYs gets about 30% better MPGs
When was gas not available? I've had a drivers license since the 1980's, never had an issue where there wasn't gas available.
Also, it's been at least a couple decades since diesel was cheaper than gas per gallon. The last year or so, it's been more than enough to cover any MPG improvements.
Feb-01-2023 09:02 AM
Feb-01-2023 07:34 AM
