โJun-21-2004 09:12 PM
We are getting closer to answers I am looking for etc.
โFeb-07-2015 09:25 PM
'06 GMC DMax CCSB 594,545 km
(368,890 miles)
2003 Citation 26RKS
.โFeb-07-2015 07:24 PM
jim summers wrote:first of all put in a lift pump (airdog, FASS) you CP3 and injectors will like it. look up EFI Live lots of good tuners out their I use rob`s tunes, put in a down pipe and 4 inch back to a muffler as it will drop you exh temps 200 degrees while towing, and a EGT gage or a CTS monitor. also install (nicktane) adapter on your fuel filter and then you can run larger better filters (CAT)
Steakman I agree. I have an 03' Dmax that I love w/ only 90k miles. Never an injector problem. I would like some specific recommendations on the things I can to do to keep it in tip top shape. And improve its performance too. I don't want to loose it. Any idea where I might find these ? There are so many diesel sites but I never see this question. thnx
โFeb-05-2015 01:43 PM
โFeb-05-2015 01:36 PM
โFeb-05-2015 01:14 PM
โFeb-05-2015 01:08 PM
โFeb-05-2015 12:53 PM
The premium $ on pre '07 diesels is stupid high and newer gasser lack the displacement to do the job...
(368,890 miles)
2003 Citation 26RKS
.โJan-28-2015 09:35 AM
โJan-28-2015 09:24 AM
Bedlam wrote:
The 8.1 V10 30-valve is available in chassis cabs from F450 to F750. The F450 and and F550 still use the 5R110 transmission while the F650 and F750 use the 6R140.
โJan-27-2015 12:51 PM
โJan-27-2015 12:13 PM
trcgolf wrote:
I guess a 8.1 isn't available in a super duty
โJan-27-2015 11:54 AM
โJan-27-2015 11:50 AM
โJan-19-2015 02:00 PM
โJan-19-2015 12:23 PM
Hannibal wrote:
So your truck idles up the grades at the speed limit towing 1k lbs more than a new 6.7L Cummins powered Ram that can only muster 44 mph foot to the floor at 2800rpm? Once moving, overall gear ratio is what puts the power to the wheels and 2800rpm foot to floor 44mph is using all the gear reduction it can use regardless of rear end ratio. The 6.7L Cummins was maxed out while your '01 idles by at the speed limit in O/D towing 1k lbs more. I'm impressed!
