Aug-07-2014 08:29 AM
Aug-08-2014 06:51 AM
Aug-08-2014 04:01 AM
Dakota98 wrote:
I checked out the link you submitted. Do you need a "programmable" stat? In my opinion that one is overkill by a long ways. With heat & cool switch + fan on or auto. With mine, it was a simple two wire hook up using the existing wires, put batteries in it for the backlit feature, set the temp, push the on button & away she goes. Unless that one happens to be less money, then maybe.
Aug-07-2014 06:03 PM
Aug-07-2014 01:57 PM
Aug-07-2014 11:51 AM
Roscopcoletrain wrote:
Thanks.
I assume this one would work no?
Thermostat
Aug-07-2014 10:31 AM
Aug-07-2014 10:00 AM
smkettner wrote:
http://www.amazon.com/Heat-Only-Digital-Non-Programmable-Thermostat/dp/B002SR9PHM#productDetails
Says battery powered but not programmable so you will need to punch it up in the morning yourself.
I installed one of these in a rental condo several years ago. No issues.
Aug-07-2014 09:06 AM
Aug-07-2014 08:52 AM
Roscopcoletrain wrote:That does present a problem. I thought hardware stores carried battery ones.
thats part of the issue. Seems like everything is 120v that I can find. Nothing battery powered.
Aug-07-2014 08:51 AM
Aug-07-2014 08:41 AM
Aug-07-2014 08:36 AM
Aug-07-2014 08:31 AM
