DIY bunk ladder
qmrichardson
You'd think new bunk models exceeding 30K would come with a ladder... My son fell from the top bunk this week after almost successfully climbing up and hurt his ankle pretty good. The ladder height I need is 55 inches, but I've mostly just seen 60 inch ladders for sell to the tune of $50-60 bucks. I built this one for $14 in wood, $7 in stain, and $7 in hooks. $28 total but it was fun to do with the kids. I'm on my fourth travel trailer, and this is the third bunk model I've had to build a ladder for. you'd think I could at least get the spacing even on the steps 🙂 I'm about the least handy person I know when it comes to wood working. I'll see if I can get this picture to post.
Will
2014 Keystone Outback Terrain 299TBH
2008 Dodge Ram 2500, 6.7 Cummins Turbo Diesel
4 REPLIES 4
happybooker1
So my current C came with an aluminum ladder. I should keep it when I sell the C? As I gather the ladders are made Cheaply now? ( this ones from '91).
2008 Tacoma Extended Cab
2009 Keystone Hideout 19FLB
Andersen "No Sway" "No Bounce" WDH
JJBIRISH
Looks good…
One of my old trailers came with one and I kept it until I no longer needed it… it may still be stored with other RV stuff I most likely will never use again and need to get rid of some day…
Love my mass produced, entry level, built by Lazy American Workers, Hornet
dodge_guy
Yep, looks good!
I built one for my previous TT I purchased new. when we bought our current TT I transferred it over. I also built mine. We are probably better off because if the manuf. offered one it would be made of balsa wood and would fall apart after the first year. I can`t give an exact weight spec, but it holds at least 200lbs!!! :B
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
brirene
Nice job!
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
“Certainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
