Does GM have it backwards?
Bowti
2019 Silverado 1500 offers a 6.2 with 420 HP and 460 lbs-ft of torque and 10 spd trans. The 2020 Silverado 2500 rumored to offer a 6.6 with 400 HP and 450 lbs-ft of torque and 6 spd trans. Shouldn't it be the other way around for these gas engines?
2013 Keystone Cougar 28SGS Xlite
Shipping weight 7561 lbs
Carrying capacity 2439 lbs
Hitch Pin 1410 lbs
2008 Silverado 2500 Duramax 4X4 Crew Cab
Reese 16K Round Tube Slider
Custom 3 Receiver Hitch Scooter Carrier
2013 Honda PCX Scooter on the Carrier
16 REPLIES 16
BenK
Duty Cycle
If you don't know what is...look it up
Basically...normal usage will have most anything do...while a 'work' or a 'HD' usage will require much more stout everything (frame, suspension, tires, wheels, drive train, etc, etc, etc) and why so many won't buy next higher class over a 'half ton' because of their main concern: "ride quality", of which higher class trucks will NOT have as good a ride quality
A lower/lowest class pickup will NOT last long with it's lower Duty Cycle design. There is a fake half ton that is almost a 3/4 ton and is offered in very, very small numbers for those who really should have a higher class pickup, but insist on a 'half ton'...
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
wnjj
The 6.6 will be able to offer its hp all day long and in more extreme conditions.
I agree that the HD truck could sure use more gears. Maybe theyโ€™ll offer the 10-speed Allison as an option someday?
