Does your dually fit in the garage?
brnzbk
I am considering buying a dually and my garage has two doors (Center post). I've measured many times and it will barely fit but I don't want to have chest pains everytime I pull into the garage.
I live in south Texas (Padre Island) 8 blocks from the beach so I would hate to leave it outside (salt mine). Does anyone else have a similar situation?
2015 F350 CC LB Lariat 6.7L Dually
2016 Cedar Creek 36CKTS
B&W Companion
31 REPLIES 31
eHoefler
Mine fits nicely in my 30' x 32' garage with 2 12' x 10' tall doors. :B
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
byronlj
Mine fits fine and goes up and down on my 2 post lift also.
Dave
byronlj
2013 Dynamax Trilogy 3800RL
The_Mad_Norsky
Width is fine for me. Length too.
But height is too low to clear the cab, so no garage for mine.
The Mad Norsky, Doll, Logan and Rocky
2014 Ram 3500 w/ Cummins/Aisin
2019 Northern Lite 10-2 EX CD LE Wet Bath
RV'ing since 1991
I took the road less traveled .....Now I'm Lost!
blofgren
Yes but I had to go to a Megacab with the short box for it to fit; the crew cab long box was too long. I would have preferred the long box, but the truck being in the garage was more important to me. The Megacab dually is also quite rare and I definitely like that about it.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
2008 Corsair Excella Platinum 34.5 CKTS fifth wheel with winter package & disc brakes
catfishmontana
Mine fits.
2016 F350 Platinum Dually, CC
2014 Cyclone 3800 toyhauler
B&W Companion 20K
larry_barnhart
Fits in our garage with plenty of room.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
45Ricochet
I wouldn't own a vehicle that wouldn't fit into a garage, too much age and depreciation involved.
8' foot door you better have good aim cause it will be tighter than a nats butt :W
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
buc1980
I wish to fit in the garage.Too long and to wide.
2017 Ford F350 DRW,2005 Kountry Star 35ft,16750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.Full body paint 2022.RV flex roof 2023
George_H
Local builders favor 1 foot post between 7 high by 8 wide doors. I removed center post, doubled header and got 7 X 17 foot door from Lowes. Dually in sig. is 7'11" across fenders.
George, Juanita and Mandie (boss Shar-Pei)
01 F350, PSD, DRW
05 Carri-Lite 32RS3
BB_TX
I can't even get my SRW in the garage, but it is because both the height and the length are too much.
TakingThe5th
I can fit thru my 9x7 door if the mirrors are retracted, but the antenna drags on the garage door as I come in. I have a moonroof and can leave that open but there will be just an inch or two of clearance as I enter the garage. I have plenty of room once in the garage because my garage doors have a 3 foot wide "post" between them.
So height can be just as tight as the width. My truck is not jacked up. Hope that helps.
Edited - The bother of parking in the garage is easily offset by having a truck that doesn't need washing as often and tires that stay fresher longer.
TakingThe5th - Chicago, Western Suburbs
'05 Ford F350 Crew 6.0 DRW Bulletproofed. Pullrite Super 5th 18K 2100 hitch.
'13 Keystone Cougar 333MKS, Maxxfan 7500, Progressive EMS-HW50C, Grey Water System.
hone_eagle
Nope 🙂
2005 Volvo 670 singled freedomline 12 speed
Newmar 34rsks 2008
Hensley trailersaver TSLB2H
directlink brake controller
-when overkill is cheaper-
Cummins12V98
OP easy fix remove center post add a nice glue lam and add one BIG door!
If you need a Dually get one no matter what!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
Arcamper wrote:
My shop has a 10'x10' door on one side and I really make sure I am centered when pulling in. This thing has a really big butt. It fits fine of course but I need to measure and see what the actual width is. I do not run my mirrors out like many do when not towing, no need unless I just want to look cool I guess.
The pay booth at our airport did make me pucker though. I had maybe two inches on each side between the tires and curb. Did not touch it though!:E
The reason I leave mine up has nothing to do with COOL. I leave them up because the spot mirrors work MUCH better in the up position.
Arcamper
2016 Montana 3100RL Legacy(LT's,Joy Rider 2's,disc brakes)
2014 Ram 3500 DRW Laramie Cummins/Aisin 14,000 GVWR
2014 Ford Expedition Limited, HD tow pkg
2016 Honda Civic EX-T
1999 Stingray 240LS
1994 Chevy 1500 5.7 PU
2018 John Deere 1025R
B&W RVK3600 Hitch
