Dometic Refrigerator not working as it should
mattyj
My Frige gave me problems on the road, I set it to Auto when on shore power and it wouldnโ€™t work , then iโ€™d switch it to LP and sometimes it would work. Now Iโ€™m home and everything works perfectly . What the heck am i doing wrong?
2006 Ford F 350, 6.0 PSD 8 Foot Bed 4x4 with Torklift Tie downs ,Stable Loads ,rear Helwig Swaybar,airlifts 5000 , Method 305 HD rims . 2019 Adventurer 89 RBS, slideout, Generator
4 REPLIES 4
egarant
Check voltages for sure, but itโ€™s your control board, they are ****. I had the same kind of problems. Buy a replacement from Dinasour, they are in Oregon. Fridge works best it ever has.
2021 FORD F350 dually 4x4 with 4.30 gears, 013 Eagle Cap 950, 480 Watts Solar, 3K Victron Multiplus II, Victron smart DC-DC charger, Victron 100/30 solar controller, 250 amps of lithium batteries by LifeBlue
mattyj
Thank you for your responses, I will definitely check these solutions out!
jimh406
If it isn't working on Auto, is the breaker on? As far as working sometimes on LP, does it work if you stay in one place and are you level? Otherwise, it could be blowing out or the propane source might not be very good.
'10 Ford F-450, 6.4, 4.30, 4x4, 14,500 GVWR, '06 Host Rainer 950 DS, Torklift Talon tiedowns, Glow Steps, and Fastguns. Bilstein 4600s, Firestone Bags, Toyo M655 Gs, Curt front hitch, Energy Suspension bump stops.
NRA Life Member, CCA Life Member
CA_Traveler
Could be low voltage. Load test the RV battery. With solar off and shore power unplugged make sure the battery is being charged from the truck alternator.
2014 Grand Cherokee Overland
Bob
