Jan-20-2019 07:09 AM
Jan-29-2019 05:02 PM
Jan-29-2019 04:42 PM
Jan-29-2019 04:33 PM
GULFMAN wrote:
Marcela,
The Dometic Fan-Tastic Vent double vent cover does it come per drilled for the lower rear hinge and the slider bar for raising?
Thanks
Jan-29-2019 06:30 AM
GULFMAN wrote:
Marcela,
Thanks
Jan-29-2019 04:19 AM
Jan-24-2019 12:23 AM
GULFMAN wrote:. I hope they do better on the newer ones.
I found no insulation behind the outdoor shower that area would freeze for sure.f
Jan-23-2019 08:19 AM
Jan-23-2019 06:54 AM
GULFMAN wrote:
Marcela,
Do you have double pain in the back door glass?
I don't on my 2005 9-6 use reflex in the lower glass with the snap on cover
Jan-23-2019 06:11 AM
Jan-21-2019 02:12 PM
bb_94401 wrote:
Best use of the double acrylic vent cover is during the spring and fall. Condensation doesn't form on the inside of the cover and it won't drip on you in bed, like the single layer version.
Jan-21-2019 01:56 PM
Jan-21-2019 06:12 AM
GoinThisAway wrote:
My 10.4 has two Fantastic Fan vents. The way the vents are made there's no recess for installing a foam pillow. So I finally replaced the single pane covers with dual pane covers from RV Upgrades last year. It was an easy install and I figure it has to help retain heat in the winter (heat rises after all), cut down on condensation, and cut down on heating by the sun in the summer.
Jan-20-2019 08:17 PM
Jan-20-2019 04:33 PM
