Sep-05-2016 06:18 PM
Sep-06-2016 04:17 PM
Sep-06-2016 04:14 PM
WayneLee wrote:Incorrect. There are 3 levels of traction control requirement
In California, it's either CHAINS REQUIRED,or no chains required. There is no in-between. The CHP determines when chains become necessary and, after that, all vehicles must put on their chains. On duals, only the outer one is required. No snow tires are acceptable.
Sep-06-2016 03:56 PM
trail-explorer wrote:DOITHARD wrote:
... also might be towing a double axle trailer...should Trailer also be chained on both axles or just one?
One should suffice.
Sep-06-2016 08:59 AM
Sep-06-2016 08:54 AM
trail-explorer wrote:Grit dog wrote:
Chain the outside rears and fronts if necessary.
If all 6 are needed to get through, you're in the wrong place!.
That was my thought too.
I know it happens that WSDOT (Snoqualmie Pass) will require chains, but it's very, very rare that it happens. Generally when it happens, I think they post it as "rigs over 10k GVW I typically monitor the DOT pass reports regularly.
If the weather over Stevens or Snoqualmie is bad enough to require chains, I don't think I'd want to be travelling in that mayhem.
Outer chains only is what I'd do.
Sep-06-2016 08:23 AM
Sep-06-2016 08:21 AM
Sep-06-2016 08:13 AM
Sep-06-2016 07:06 AM
Sep-06-2016 07:04 AM
Sep-05-2016 11:55 PM
Trackrig wrote:
To paraphrase Grit Dog above - if you need chains on the trailer also, you're in the wrong place. Park it and wait.
Bill
Sep-05-2016 10:10 PM
Sep-05-2016 09:28 PM
Sep-05-2016 08:42 PM
Sep-05-2016 08:40 PM
