Electrical outlets
Youda97
I have a 2015 Forest River Evo camper trailer. I am new to the camper trailer world. This weekend is my first week and dry camping. Do my electrical outlets only work when I have my generator running? I guess I assumed that the electrical outlets would run off the battery until the battery was dead. Thank you in advance for your answers.
13 REPLIES 13
krobbe
I just received this from Amazon. VicTec DC voltmeter
It's a low cost permanently mounted display for the battery voltage.
I mounted it above my Progressive Industries Electrical remote display.
Me'62, DW'67, DS'04, DD'07
'03 Chevy Suburban 2500LT 4WD Vortec8.1L 4L85-E 3.73 CurtClassV
'09 BulletPremier295BHS 33'4" 7200#Loaded 1100#Tongue Equal-i-zerHitch Tires:Kumho857
Pics
time2roll
Youda97 wrote:
Thank you for the detailed response. It was very helpful. I have a 3250 w gen. Will 2 hours be enough charge the battery fully or about to what level? IE 25% ect.
Depends on charging voltage and amp rating. Some converters are excellent, most are weak, many are pathetic. Post what you have for best recommendations.
BubbaChris
Let's say you're going to be gone 1-2 nights, you might not need to run the generator at all.
This assumes the following:
You have the TT hooked up to 115V at home (or at storage) and the batteries are fully charged when you leave.
You have 2 batteries rather than just one.
You have LED lights, or will be careful with how much you use the lights
You don't need the furnace to run more than a few times through each night.
You will be hooking your TT back up to 115V when you get home.
I still take our generator with us on most dry camping weekends, but I rarely run it now that I know what we're capable of. It's similar to learning how well we can manage our fresh/gray/black tanks without hookups.
2013 Heartland North Trail 22 FBS Caliber Edition
2013 Ford Expedition EL with Tow Package
time2roll
You need to add an inverter to create 120v from battery power.
300w for small stuff is fairly easy. Laptop, phones, tv, dvd, satellite are good to go.
Coffee, microwave, hair dryer, compressor need 2000 watt inverter and at least four batteries. Install is a bit more complex also.
The 12 Volt Side of Life
blt2ski
Moderator
Moderator
Moving to travel trailer per request of OP.
Marty
TV moderator
92 Navistar dump truck, 7.3L 7 sp, 4.33 gears with a Detroit no spin
2014 Chevy 1500 Dual cab 4x4
92 Red-e-haul 12K equipment trailer
krobbe
Since you are talking about boondocking, you'll want to bring the batteries back to 90% when running the genny. Letting the battery voltage drop below 12.00Vdc(50% charge state) will shorten the life of the battery.
Here is a 12v battery voltage State of Charge chart:
12.6+ = 100%
12.50 = 90%
12.42 = 80%
12.32 = 70%
12.20 = 60%
12.06 = 50%
11.90 = 40%
11.75 = 30%
11.58 = 20%
11.31 = 10%
10.5 = 0%
When using the batteries under these conditions, check the electrolyte levels frequently. Be sure to use distilled water to refill the levels. Minerals in tap/well water will shorten the life as well.
Check out this 12vdc Voltage Meter to keep an eye on your battery state of charge.
Pics
Executive45
Does the EVO have an INVERTER..? If so, the outlets will work if you turn it on. It will kill your batteries pretty quickly though, depending on your battery bank....Dennis
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
Monaco Executive M-45PBQ Quad Slide
525HP Cummins ISM 6 Spd Allison
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
Perrysburg_Dodg
Youda97 wrote:
I have a 2015 Forest River Evo camper trailer. I am new to the camper trailer world. This weekend is my first week and dry camping. Do my electrical outlets only work when I have my generator running? If you have a generator and you are not talking about the alternator on your tow vehicle then yes your 110 volt outlets will work. I guess I assumed that the electrical outlets would run off the battery until the battery was dead. Thank you in advance for your answers.
If you do not have a portable generator and you are going to be doing a lot of dry camping, I would go with two 6 volt golf cart batteries. You also may want to look into a solar panel. Ask the Mod to move this to the TT section for you.
Don
2015 Ram 1500 Laramie Crew Cab SWB 4X4 Ecodiesel GDE Tune.
Youda97
shepstone
Not unless you plug the umbilical into a 1,000 watt inverter and power the whole rig through it , I upgraded to 2- 6 volt crowns a couple of months back and tried it for a weekend , it kept up quite well I still had 2/3 power left although I only ran the tv and bluray for the most part and the microwave once , thing that sucked the power most was the lighting , so I have now installed leds throughout . Just remember to turn the rv's power converter off.
2017 F350 Ruby Red Super Cab Dually 6.7 3.55 gears. B&W Companion 25K. BackRack. Gatorback mud guards. AUX65FCBRG aux tank. 2021 GD 380fl
2010 GMC Savanna 3500 extended 6.0
mtofell1
newman fulltimer wrote:
How will 110 outlets run off 12volts?
The OP openly admitted he's new.... how exactly does your post help at all?
To the OP, you are correct. The standard house type outlets in the TT will only work when plugged into shore power or a generator. Your interior lights and water pump will work off the battery so you can "survive." Your furnace would likely work as well but beware it will deplete the battery quickly due to the blower fan. A/C won't work unless on shore power or a beefy generator (don't try unless you have a 3000W or bigger generator).
The way I use my generator is to run it a couple hours during the day to charge the batteries and/or if I want to throw something in the microwave. That way I generally have enough juice to get through the night w/o running the generator (frowned upon during sleeping hours, for sure - unless you're really away from it all and no one can hear it)
Also, if you have a dual gas/electric water heater be sure to turn off the electric side of the water heater so it doesn't kick in and over work the generator when you turn it on. On most modern heaters there is a switch behind the panel accessed from the outside. If your water heater is only gas you have nothing to worry about.
Youda97
Ahhh. Ok. Outlets run off 110v and battery is only 12. Ok that makes sense. Thank you. Again, very new to this thing.
newman_fulltime
