โApr-24-2014 12:02 PM
โApr-25-2014 07:13 PM
โApr-25-2014 07:01 PM
cpaulsen wrote:
Go to the Ford Superduty forums and search for overhead display. It will have a lot of info on fixing the problem. Mine did the same as yours and I fixed it. There are some resistors that the solder comes loose on which causes the problems.
โApr-25-2014 07:00 PM
tim and amy wrote:
It's a common problem that has to do with a Relay sticking. If you cycle the head light switch on and off a few times the HVAC control will turn back on. Dumb I know. FYI it is caused by the ACC timer relay.
โApr-25-2014 03:52 AM
โApr-24-2014 09:55 PM
