Mar-05-2017 05:13 PM
Mar-05-2017 10:15 PM
Mar-05-2017 08:09 PM
Mar-05-2017 08:01 PM
Kayteg1 wrote:
That was at the time when Utah had diesel like 30-40percent cheaper than California and California fuels have been diluted to deliver less mpg.
Mar-05-2017 07:18 PM
Mar-05-2017 07:14 PM
Mar-05-2017 07:06 PM
Reddog1 wrote:NRALIFR wrote:I agree with Lwiddis. For me it is like spending $1000 to increase your MPG by 1 mpg. I cannot imagine breaking even in your lifetime, much less your trucks lifetime. To spend that kind of money cause you can, okay. To spend that money for bragging rights, okay. But if you do note frequently drive cross country, I can't see any advantage. How much will it cost to haul the extra fuel?Lwiddis wrote:
Your money but a 370 mile range isn't limiting in my view.
It's not just the added range that makes a bigger tank advantageous. It also gives you the opportunity to be more selective about where you buy your fuel, and bypass a high-cost area entirely. While my current truck doesn't have an after-market fuel tank, a previous truck did and I loved it. I carried a total of 65 gallons between two tanks. Did I always use the full range it gave me? No. But as I said, it's not just about range. It was there if I needed it, which I did a few times.
I would go for the biggest, which would be the 67 gallon Titan. I also like the fact that it's plastic. As long as it's adequately protected, plastic would be superior IMHO.
Wayne
Mar-05-2017 06:52 PM
Mar-05-2017 06:26 PM
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Mar-05-2017 06:03 PM
Jaxom wrote:
Like you did with your rig, go big.
I like having the option to fill where I want to instead of where I need to. Different states have different tax rates for fuel. Some states are cheaper than others. Some states I prefer to NOT buy fuel in.
I can't speak to the Titan as I have an in-bed auxiliary tank.
Good Luck.
Mar-05-2017 05:58 PM
fpoole wrote:
I got the 2nd tank on mine, standard 22 gal, extended 50gal for total of 72Gal...
Great when driving...
Not so great when I have to fill them..
9.5 - 10.5 mpg or so..
I'd get 57.. big enough without selling the truck for a fill up.. heheh,
fun..
Mar-05-2017 05:49 PM
Mar-05-2017 05:47 PM
Mar-05-2017 05:41 PM
Boatycall wrote:
I'm looking into replacement fuel tanks. I'd like to hear from folks who have replaced the existing tank with a larger replacement. Since I haul a TC, can't use a bed tank like I did when I had a 5'er. Also don't want a spare tire replacement tank...I like having a spare.
Stock tank is 37 gallons. Fully loaded, depending on where I go, I get 10-11mpg. Usually, it's my arse saying it's time to stop and take a fuel break before my gauge says to. But sometimes, it would be nice to have a little extra range.
I've found three so far for my truck, these are the best prices I could find--.
-Titan 67 gallon, ABS plastic, $1409 free shpg
-Aerotanks Aluminized Steel, 60 gallon, $980 + $170shpg
-TransferFlow Aluminized Steel, 57 gallon $1185 free shpg
Any thoughts?
Mar-05-2017 05:38 PM
Mar-05-2017 05:35 PM
