F150 OK for 5ver @ 7000lbs Dry??
Peripatetic_Pul
Hi All:
Ford dealer says F150 bed payload not strong enough for Keystone Cougar 244RL Dry at 7klbs and we must purchase an F350.
Any input greatly appreciated - F150/F250/F350?
Thanks!
19 REPLIES 19
Peripatetic_Pul
You are ALL FAbUluZzzz! Thanks! Need to haul a trailer to Costa Rica and there is no ULSD (diesel) between here & there. Yes, bigger is better but Crikey! another $10k+
downtheroad
Got to love it.
RV Dealer says, "Sure you can pull it with that, no problem."
Truck Dealer says, "Can't pull it with that, you need a bigger more expensive truck."
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
TucsonJim
According to the Keystone spec sheet, the 244RLS has a pin weight of 1270 pounds. Just for safety sake, I'd go with 1400 pounds to account for the loading and balance in the Cougar.
According to the Ford Website there are many combinations of vehicles and drive trains in the F150 that provide variable payloads. Check out this site, and you'll find that there are F150s which will be able to carry your pin weight, people and other cargo. But many will not.
Ford Payload Data
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
Terryallan
The pin weight of the 5er will more than likely be more than the payload rating of the 150. You would be much better with a 250, or 350
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
Golden_HVAC
The heavy duty F-150 with tow package, 3.5L Ecoboost, and other high GVWR packages, Ford rates them to carry almost 3,000 pounds. The F-250 has about the same capacity, even with it's much higher GVWR, the truck base weight is much higher.
In 2015, the F-150 will have a all aluminum body, and you might want to wait until August to get one of those. The body can not rust through, and will be about 200 - 300 pounds lighter than the 2014.
As for mounting the hitch, that should be able to happen with either truck.
What will be the dry hitch weight?
How much do you plan on putting in the truck while camping?
Those two answers will be part of if the F-150 will be acceptable. If you have a heavy family, and want to carry a lot in the truck, then the F-350's 4,000 pound cargo rating will get the job done. With the F-150 or F-250, you would need a calculator to figure out if you will be fine or not.
By heavy family, I am stating that you might have 2 adults at 200 or so pounds each, and three kids around 120 - 150 pounds each. It all adds up to something around 700 - 800 pounds. That can take away a lot of the F-150's cargo rating, while it will hardly effect the F-350 cargo rating.
Best thing to do is read the towing guide, and understand what can be put into the trucks. You might also need to go to another local Ford dealer, they might be ordering more of the 3.5L F-150 with heavy duty towing package.
Once the new aluminum body comes out, then the Ford dealers will have a more difficult time pushing the older steel body trucks, you might get a better deal on one.
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
