Fantastic fan with no thermostat?
Kayteg1
Installed Fantastic fan I bought years ago and now I notice that even it is upper class model with electric lid and rain sensor - it does not have thermostat.
So when I try to open it on colder day, I have to switch to manual crank.
Than when I leave it open with crank to auto, at some point at end of the day it will close.
So does it have set thermostat that I can't adjust?
What would be the setting?
20 REPLIES 20
Truckinguy
Call Fantastic they will straighten you out on what you have,need or to do.They have excellent service. At least they did up until last year when I needed help.
Kayteg1
AnEv942 wrote:
Sounds odd, lid closing. Unaware of any F/F that had a fixed non adjustable thermo. Those that did have thermo were adjustable, visible on face, and to my knowledge it turned on/off motor, (thouhg may also open lid-not sure of operation)
Couple of listings showing older unit manuals...
pdxrvwholesale
fantasticvent.net
Wonder if lack of remote part of issue. (Don't recall any f/f with a remotely mounted manual switch, only remote controllers. pdxrv shows various controllers offered.
Thanks for the links. I went via both lists and looks like I have unicorn.
Again, this is older unit where remotes did not exist, but all listings show manual crank with motor switches, or electric crank with thermostat.
Nowhere the model with electric lid and rain sensor, but no thermostat shows.
Oh well, I will have to figure it out the hard way, or just use manual cranks.
However playing with it today, when I pull the knob to manual opening and then turn the switch to on, the lid motor will keep on running. Seems it has electronic circuit that turns the power off at certain current aka when motor comes to end of travel.
AnEv942
pdxrvwholesale
fantasticvent.net
01 Ford F250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page
http://www.ourelkhorn.itgo.com
Kayteg1
You have newer model, when I can't find model # on mine.
It was produced in years when wireless remotes were not available, although I have 2 additional wires marked "remote" on it, what I believe would be remote switch.
I search the manuals on the net and even those marked as "older" cover newer technology.
Hate to have electric lid and operate it manually simply from lack of manual.
Siletzspey
What model of Fantastic Fan (FF) do you have?
On my FF, the remote control lets me set a speed (13 possible speeds) or a temperature, and it automatically opens/closes the lid and has a rain sensor. Without the remote, the fan unit has a manual open/close knob but no other controls, and manually opening the lid will turn the fan full on. I'm sure the rain sensor would close the lid upon rain. I have no idea if the last temperature set BY THE REMOTE would still be utilized when manually opening the lid.
--SiletzSpey
Lwiddis
I have the complete cheapo! Manual everything. Sorry I can't help.
