fifthwheel brake wiring
Trailer_Bob
When traveling in dry conditions, everything works fine, brakes, lights, turn signals,etc. However when it starts to rain truck (98 F3 50) message center says trailer disconnected. Although I still have all lights, but brakes don't work until it drys out. Truck has added in bed socket. Scotch connecters were removed and replaced with soldered connections and covered with three coats of liquid tape. Then wrapped in regular electric tape. The problem still presists when it rains. Any suggestions?
4 REPLIES 4
BB_TX
Check wiring at axles and wheels for any place where the wiring insulation may have rubbed thru.
Trailer_Bob
That is my next move, Thanks
john_bet
Try redoing the connections at the axles. I had two go bad this year resulting in no brakes so I just redid them all.
2018 Ram 3500 SRW CC LB 6.7L Cummins Auto 3.42 gears
2018 Grand Design 337RLS
1492
Moderator
Moderator
Moved from Forum Technical Support
