Fixing A FORD Truck 5.4 Liter Intake Manifold Coolant Leak
Camper_Jeff___K
Nomad III
Nomad III
Easy Way To FIX A Leaking FORD Intake Manifold
I've had an F250 with a 5.4 liter engine for many years. Over those years, the 5.4 liter engine has developed a coolant leak at the front right of the engine. Ford placed the first and second intake manifold bolts about 5 to 6 inches apart which makes a wide gap of no pressure on the coolant crossover tube in the front right of the engine. This is a very common failure with this engine, also the 4.6 and the V10. The way to fix it has been to replace the intake manifold gaskets and often the intake manifold too with a Dorman manifold. A very cheaply manufactured excuse for a replacement part. Ford has stopped making the replacement manifold. There are no after market options available either. In a desperate move, not wanting to go through the process of removing and reinstalling my manifold again, I decided to try something different. I looked at the situation and came up with a simple way to fabricate a simple part and install it in the first bolt location. This FIX is a 2-1/4" x 3/4x3/4 Stainless Steel square stock drilled to take an 8mm 4.5" length of grade 8 all thread. I applied liberal Anti-seize to the threads and ran it down into the head till it bottomed, then torqued an 8mm flange nut to 18 pounds. I fashioned the cleat piece to fit contoured to the aluminum crossover tube where it presses directly centered over the coolant passage and was tightened down to 10 pounds torque, it pressed down on the crossover tube, and evenly flattened the manifold to the head stopping the coolant leak. The repair has been installed for a week now and the coolant system holds pressure and keeps holding pressure for hours after shut down. This is a repair that can be installed on an engine without changing the gaskets or doing any other work to the engine. Of course not all results will be the same but in my case, I am very pleased. This is also a repair that can be installed on an engine before the inevitable leak ever happens. I did not replace my gasket or do any other work to my truck engine other than this fix. The existing gaskets have sealed completely and I have no further leakage.
This is a very common with the Ford modular engines and I'm sure a few folks in the RV.NET community are having or have had this issue and will hopefully benefit from this information.
Best Wishes!
3 REPLIES 3
Camper_Jeff___K
Nomad III
Nomad III
jjj wrote:
Good to know about this fix, I have a 2002 F-350 with the V-10. I only have 38,000 miles on it and no sign of trouble but good to know there is a possible fix. If possible pictures would be nice. Congrats on your ingenuity.
Pictures tend to be a pain. If I link Facebook Pictures, Only people logged into facebook can see them. If I link to MSN Cloud, only certain people can see those. Photo Bucket and other services have a limit on views. I can post to my own website but that is time consuming. The easiest way to post is YouTube. Some like it, Some hate it. It does allow for the story to be told set to a video. Some people are good at it, others are just so so. Let's just say I will never win an award for cinematography, but I do have fun and enjoy the making a video process.
You can also install this simple fix before a leak ever happens. I suspect with the modification, the leak will never happen.
Take Care...
jjj
2002 F-350 Crew-Cab Dually
V-10-4.30 gears Mag-Hytec diff.cover
w/Amsoil-6.0 trans cooler Curt Q5 20K hitch & bedsaver
2005 Keystone Challenger 34TBH-Fifth Airbourn
Camper_Jeff___K
Nomad III
Nomad III
The fix has been working without fail for over a week and a couple hundred miles now. It saved me from the time and expense of removing the top end, installing new gaskets, or replacing the intake manifold with the crumby Dorman one. All in all, pretty darn happy how this worked out.
Installed a new NAPA stainless steel muffler last night and hoping to get and install new semi-metalic brake pads today. A few more projects on the house and camper, then we'll be ready to go get ourselves in position to observe the Annular Solar Eclipse.
Good Times!
