โSep-10-2016 05:51 PM
โSep-12-2016 07:01 AM
โSep-12-2016 06:53 AM
LOFAT36 wrote:Better durability and higher speed ratings.
Okay my question is why should I go to light truck tires as opposed to trailer tires ? I do no off roading unless you consider a 1/8 mile of gravel off road. I don't get it, better ride, stability, price ? Please explain.
โSep-12-2016 05:55 AM
โSep-12-2016 03:10 AM
rbpru wrote:Interesting take.
That is, manufacturers use the type of tires they believe is suitable for their intended application.
โSep-12-2016 02:01 AM
brirene wrote:Someone before you just stated that the 'new Carlise has been out 5 years.
Wow, lots of old information being tossed around here. 2006? Low speed ratings? How many threads have you seen recently about "China bombs"? Except for the brother of my uncle's girlfriend on her mother's side had a blowout 8 years ago. Used to be on here all the time. Carlisle has improved their design already over one that I've yet to see a bad review about. Higher speed ratings too. I don't care what tires anyone runs. As was stated, it's your money. But at least base your argument on information from the current decade.
โSep-11-2016 10:43 PM
โSep-11-2016 09:49 PM
โSep-11-2016 08:48 PM
โSep-11-2016 08:23 PM
โSep-11-2016 08:18 PM
โSep-11-2016 08:12 PM
rbpru wrote:
The TT manufacturers put over a million STs on the road every year on their tow behinds and 5vers.
โSep-11-2016 07:54 PM
โSep-11-2016 07:45 PM
brirene wrote:Well I WAS one of those ST believers and threw a LOT of money away on inferior ST tires, before I finally made the switch around 2006 to LTs. Not a problem since.Huntindog wrote:
As usual, whenever this topic comes up... An ST fan will make all sorts of excuses as to why ST tires fail, such as curbing, over speeding, under inflating, the sky is blue etc.. Then smugly proclaim that those who had ST tire failures simply did not understand the limitations of the ST tire design... And that when used within their limitations they will give good service.
To that I say that many of us DO understand the ST tires limitations. We DO understand the much lower testing standards for the ST tires, and we find those limitations.......... Well, limiting.
And just as predictably, LT folks will come along and smugly and condescendingly explain that anyone who uses ST's really doesn't understand, is kind of simple minded and easily duped, and doesn't mind throwing their money away on an inferior product, totally dismissing the miles collectively towed without issue. Apparently, one can only really understand (wink, wink) the issue if they're using LT's. Once again, research and use what YOU'RE comfortable with. ๐
โSep-11-2016 07:31 PM
โSep-11-2016 06:28 PM
smkettner wrote:x2. Knows it's been flogged but hasn't bothered to read them??
Have you read a hundred tire threads and still cannot decide?
