Folding Step Leg maintenance
PApopup
On our last trip, the site was not quite level and we had to raise the entry side 3 to 4 inches. We have the newer folding steps with the adjustable legs. Given the height difference when we release the adjustable legs they actually fell out. So slid them in till they clicked and put some blocks. Worked ok.
Come to leave and have a hard time sliding them all the way into the unit. Is there a trick for getting them to work again? We hold the release but it binds very quickly. Since they folded up we left them and headed home. Now need to get them working. Any thoughts?
Bob, Kim, Gabby, & Matt:)
2011 Flafstadff V-Lite 30WTBS ๐Ÿ˜„
2010 Chevrolet Silverado 2500 LT Crew Cab 4X4 :B
2 REPLIES 2
Boomerweps
Take them out, wipe any rust off, spray them down with lube (especially any spring loaded locking balls), reassemble. Mine uses removable pins.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, ITBC, SumoSprings,
Grit_dog
Nomad III
Nomad III
Hit them a little harder with your purse?
